[Geomoose-users] Pink layer error
Brent Fraser
bfraser at geoanalytic.com
Wed Jan 20 14:40:46 EST 2010
Franz,
The messages from mapserver indicate your
/home/myghanas/other/search/maps/demo/countydata/ghana.map has:
- an OUTPUTFORMAT of agg, but mapserver doesn't agg compiled in
- the parsing error below. The line number is including any "INCLUDE"
files your map file uses
Check all the .map files you are using.
Brent Fraser
> Dear friends,
> I am greatful for your help in building my geomoose application. Please
> follow this link to get to it
> http://www.myghanasearch.com/search/mview.html But there is an error with
> one of my layers I just can't fathom. It works fine when I am offline. The
> error says;
> MapServer MessageloadSymbol(): Unable to access file. Parsing error near
> (C:\ms4w\apps\geomoose2\maps\symbols\Q2.png):(line 267) Apparently there
> is no line 267.
> and here is my mapfile. Thanks very much. Franz Okyere. GIS Specialist
> # Map file created from QGIS project file C:/Users/Franzy/Documents/GIS
> Data/LinxMb.qgs
> # Edit this file to customize for your map interface
> # (Created with PyQgis MapServer Export plugin)
> MAP
> NAME ghana
> # Map image size
> SIZE 800 650
> UNITS meters
> TRANSPARENT FALSE
> FONTSET "../../fonts/fontset.list"
> SYMBOLSET "../../symbols/symbol.sym"
> EXTENT 44122.792792 523627.732277 1391863.961749 1236515.357466
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 150 150 255
> IMAGEQUALITY 95
> IMAGETYPE gif
> OUTPUTFORMAT
> NAME gif
> DRIVER 'GD/GIF'
> MIMETYPE 'image/gif'
> #IMAGEMODE PC256
> EXTENSION 'gif'
> END
> # Legend
> # Web interface definition. Only the template parameter
> # is required to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should
> # write its output.
> IMAGEPATH '/tmp/'
> # Set IMAGEURL to the url that points to IMAGEPATH
> # as defined in your web server configuration
> IMAGEURL '/tmp/'
> # WMS server settings
> METADATA
> 'wms_title' ''
> 'wms_onlineresource'
> 'http://my.host.com/cgi-bin/mapserv?map=wms.map&'
> 'wms_srs' 'EPSG:4326'
> END
> #Scale range at which web interface will operate
> # Template and header/footer settings
> # Only the template parameter is required to display a map. See
> END
> LAYER
> NAME 'ghanaregions'
> TYPE POLYGON
> DATA './ghanaregions'
> METADATA
> 'wms_title' 'ghanaregions'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> CLASS
> NAME 'Parcels'
> STYLE
> WIDTH 5
> COLOR 255 255 255
> OUTLINECOLOR 255 0 0
> END
> END
> END
> LAYER # City Boundary Polygon Layer
> NAME city_labels
> STATUS ON
> MAXSCALEDENOM 1559055
> MINSCALEDENOM 90708
> TYPE annotation
> LABELITEM 'NAME'
> LABELCACHE ON
> CLASS
> COLOR -1 -1 -1
> LABEL
> TYPE TRUETYPE
> FONT vera_sans
> MAXSIZE 10
> SIZE 8
> MINSIZE 8
> #ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 255 255 128
> BUFFER 2
> END
> END
> END # City Boundary Polygon Layer
> END
> #Note there are 111 lines of code in the mapfile
> _________________________________________________________________
> Send us your Hotmail stories and be featured in our newsletter
> http://clk.atdmt.com/UKM/go/195013117/direct/01/
> Throughout its 18-year history, RSA Conference consistently attracts the
> world's best and brightest in the field, creating opportunities for
> Conference
> attendees to learn about information security's most important issues
> through
> interactions with peers, luminaries and emerging and established
> companies.
> http://p.sf.net/sfu/rsaconf-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
