[Geomoose-users] Pink layer error
Lund, Brent (ADM)
Brent.Lund at state.mn.us
Wed Jan 20 14:47:04 EST 2010
Line 267 is referring to your symbol file ("../../symbols/symbol.sym")
From: FRANZ OKYERE [mailto:franzzoa at hotmail.com]
Sent: Wednesday, January 20, 2010 1:27 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Pink layer error
Dear friends,
I am greatful for your help in building my geomoose application. Please follow this link to get to it http://www.myghanasearch.com/search/mview.html But there is an error with one of my layers I just can't fathom. It works fine when I am offline. The error says;
loadSymbol(): Unable to access file. Parsing error near (C:\ms4w\apps\geomoose2\maps\symbols\Q2.png):(line 267) Apparently there is no line 267.
and here is my mapfile. Thanks very much. Franz Okyere. GIS Specialist
# Map file created from QGIS project file C:/Users/Franzy/Documents/GIS Data/LinxMb.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME ghana
# Map image size
SIZE 800 650
UNITS meters
TRANSPARENT FALSE
FONTSET "../../fonts/fontset.list"
SYMBOLSET "../../symbols/symbol.sym"
EXTENT 44122.792792 523627.732277 1391863.961749 1236515.357466
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 150 150 255
IMAGEQUALITY 95
IMAGETYPE gif
OUTPUTFORMAT
NAME gif
DRIVER 'GD/GIF'
MIMETYPE 'image/gif'
#IMAGEMODE PC256
EXTENSION 'gif'
END
# Legend
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/tmp/'
# WMS server settings
METADATA
'wms_title' ''
'wms_onlineresource' 'http://my.host.com/cgi-bin/mapserv?map=wms.map&'
'wms_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
END
LAYER
NAME 'ghanaregions'
TYPE POLYGON
DATA './ghanaregions'
METADATA
'wms_title' 'ghanaregions'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'Parcels'
STYLE
WIDTH 5
COLOR 255 255 255
OUTLINECOLOR 255 0 0
END
END
END
LAYER # City Boundary Polygon Layer
NAME city_labels
STATUS ON
MAXSCALEDENOM 1559055
MINSCALEDENOM 90708
TYPE annotation
LABELITEM 'NAME'
LABELCACHE ON
CLASS
COLOR -1 -1 -1
LABEL
TYPE TRUETYPE
FONT vera_sans
MAXSIZE 10
SIZE 8
MINSIZE 8
#ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 255 255 128
BUFFER 2
END
END
END # City Boundary Polygon Layer
END
#Note there are 111 lines of code in the mapfile
Do you have a story that started on Hotmail? Tell us now<http://clk.atdmt.com/UKM/go/195013117/direct/01/>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100120/3afc43d0/attachment.html
More information about the Geomoose-users
