[Geomoose-users] some (last I hope!) questions
Dan Little
danlittle at yahoo.com
Thu Jan 21 09:02:30 EST 2010
Re 1:
Goto the Mapfile and find the appropriate LAYER, then add a TOLERANCE entry and play around with the number until it suits you. (See MapServer documentation for more information).
Re 2:
Having the column in Postgres and the attribute set as you described should work fine. You may need to call it "image_url" instead of "url" as "url" may be a reserved MapServer-template word.
Re 3:
That does sound goofy can you attach your mapbook to a follow up post so we can see the service entry for the popups?
>From: Efstathios Arapostathis <e.arapostathis at gmail.com>
>To: geomoose-users at lists.sourceforge.net
>Sent: Wed, January 20, 2010 4:22:32 PM
>Subject: [Geomoose-users] some (last I hope!) questions
>>Hello,
> I have some last problems in using the api, I would like to help me if you could.
>1. When I'm using identify tool in a point layer I have to try some time in order to select the specific point. Is there any way to increase the identify tool's tolerance?
>2. In identify.html I added some very simple html in order to have images loaded:
><img src="[url]"/>.
>In my postgis table, I created a column called url. In there, are specified the urls of the images that I want to be shown each time. For example when I'm using the identify tool to see info about point1, I want point1.gif to be loaded.
>How could I do this?
>3. When I'm using popup service, the information is shown in the catalog tab of geomoose, instead of a popup. What could be wrong?
>Thank you very much
>With appreciation
>Stathis Arapostathis
>Geographer / MSc student
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100121/b6c6a770/attachment.html
More information about the Geomoose-users
