[Geomoose-users] question on invisible layers
Jim Dahl
jim.dahl at mail.co.douglas.mn.us
Mon Jul 26 14:56:48 EDT 2010
Yes I want to get a return on the invisible layers, but do not them
printed unless the visible ones are on. Apparently there is no way to
control which TURNED ON layers are printed. I thought there was a
setting whether to include on print. I can not find it though.
Some one must know what I am referring to.
jim
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Monday, July 26, 2010 11:20 AM
To: Jim Dahl
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] question on invisible layers
Jim,
You shouldn't need to have two layers. Unless you want GeoMoose to
return
the Identify information even if the layer is turned off (i.e not
visible on the
map)?
Best Regards,
Brent Fraser
Jim Dahl wrote:
> Hi,
> I am putting in layers twice. The first is so they can turn on to
> look
> at. The second one is so they are always turned and to make
> them identifiable. This seems to work OK, let me know if you are
aware
> of a potential problem. However, my problem is this - when you print
the
> PDF shows these layers and they cover up other objects. I know there
is
> a file to set what gets printed but forget where it is. Can someone
> give me a suggestion? thanks,
> <group title="Postal Boundaries" expand="false" tip="Click to expand
> and
> turn on/off selection of Layers">
> <map title="Zip Codes" opacity="50" default="false" legend="true"
> reference="false" tip="Postal Boundaries">
> <file>/ms4w/apps/GeoMOOSE/douglas/maps_douglas/zip/postal.map</file>
> </map>
> <map title="Zip Codes identify" invisible="true" opacity="00"
> default="true" legend="true" reference="false" tip="Postal
Boundaries">
> </map>
> </group>
> Jim Dahl, GISP
> GIS Coordinator
> Douglas County Public Works
> 526 Willow Dr
> PO Box 398
> Alexandria MN 56308
> V 320-762-2933
> 320-762-2999
> F 320-762-2998
> The Palm PDK Hot Apps Program offers developers who use the
> Plug-In Development Kit to bring their C/C++ apps to Palm for a share
> of $1 Million in cash or HP Products. Visit us here for more details:
> http://ad.doubleclick.net/clk;226879339;13503038;l?
> http://clk.atdmt.com/CRS/go/247765532/direct/01/
> Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
