[Geomoose-users] question on invisible layers
Brent Fraser
bfraser at geoanalytic.com
Mon Jul 26 15:04:39 EDT 2010
Jim,
I think if you set
STATUS OFF
in your map file it should work with your current config of using two map-source
entries in the mapbook pointing to the same map file.
Brent
Jim Dahl wrote:
> Yes I want to get a return on the invisible layers, but do not them
> printed unless the visible ones are on. Apparently there is no way to
> control which TURNED ON layers are printed. I thought there was a
> setting whether to include on print. I can not find it though.
> Some one must know what I am referring to.
> jim
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Monday, July 26, 2010 11:20 AM
> To: Jim Dahl
> Cc: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] question on invisible layers
> Jim,
> You shouldn't need to have two layers. Unless you want GeoMoose to
> return
> the Identify information even if the layer is turned off (i.e not
> visible on the
> map)?
> Best Regards,
> Brent Fraser
> Jim Dahl wrote:
>> Hi,
>> I am putting in layers twice. The first is so they can turn on to
>> look
>> at. The second one is so they are always turned and to make
>> them identifiable. This seems to work OK, let me know if you are
> aware
>> of a potential problem. However, my problem is this - when you print
> the
>> PDF shows these layers and they cover up other objects. I know there
> is
>> a file to set what gets printed but forget where it is. Can someone
>> give me a suggestion? thanks,
>> <group title="Postal Boundaries" expand="false" tip="Click to expand
>> and
>> turn on/off selection of Layers">
>> <map title="Zip Codes" opacity="50" default="false" legend="true"
>> reference="false" tip="Postal Boundaries">
>> <file>/ms4w/apps/GeoMOOSE/douglas/maps_douglas/zip/postal.map</file>
>> </map>
>> <map title="Zip Codes identify" invisible="true" opacity="00"
>> default="true" legend="true" reference="false" tip="Postal
> Boundaries">
>> </map>
>> </group>
>> Jim Dahl, GISP
>> GIS Coordinator
>> Douglas County Public Works
>> 526 Willow Dr
>> PO Box 398
>> Alexandria MN 56308
>> V 320-762-2933
>> 320-762-2999
>> F 320-762-2998
>> The Palm PDK Hot Apps Program offers developers who use the
>> Plug-In Development Kit to bring their C/C++ apps to Palm for a share
>> of $1 Million in cash or HP Products. Visit us here for more details:
>> http://ad.doubleclick.net/clk;226879339;13503038;l?
>> http://clk.atdmt.com/CRS/go/247765532/direct/01/
>> Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
