[Geomoose-users] Some quick questions
Brent Fraser
bfraser at geoanalytic.com
Tue Mar 9 15:49:08 EST 2010
For anyone still using GM v1.6.1, I finally got around to tracking this down.
If you have this problem, you need to upgrade the excanvas.js (in the
htdocs\contrib folder) to a version compatible with IE8. I've tested with
excanvas_r3 (Release 3 at
http://code.google.com/p/explorercanvas/downloads/list) and it seems to fix the
problem.
Best Regards,
Brent Fraser
Brent Fraser wrote:
> The measure tools in GM v2 work ok with IE8.
> GM v1.6.1 with IE8 has a problem in that the lines/polys don't show when you're
> drawing them, even thought distances/areas are shown on the pane.
> Time to log a bug?
> Brent Fraser
> t faustino wrote:
>> Hi folks,
>> Seems I am having problems getting Measure distance and Measure Area
>> to display in IE8; I see script writing the distances/areas but no
>> visual. Works fine in Firefox. Is this a known bug with IE8?
>> How to adjust the zoom level of Searches?
>> Thank you in advance.
>> Antonio
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
