[Geomoose-users] identify maps
Len Kne lkne at houstoneng.com
Mon May 3 10:36:12 EDT 2010
If you can post your mapbook and relevant map file, we can take a further look.  The error is referring to the shape GM is sending to do the query.
Len
From: Dieter Lehmann [mailto:dieter.lehmann at hfwu.de]
Sent: Sunday, May 02, 2010 8:39 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] identify maps
Hello,
I' m having problems with the identify tool. I'm getting the following error:
Fatal error: Call to a member function queryByPoint() on a non-object in/var/www//temp/htdocs/php/identify.php on line 125
With the parcel - demo the identify is no problem.
Any hints?
Could the cause somehow be my projection? I'm using wgs84 (epsg:4326) for my application.
If someone have a cookbook for adding new layers plus identify them that would be great - in the wiki this is  missing for geomoose 2 or at least I couldn't find it.
Thanks,
Dieter
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100503/c3549b25/attachment.html
More information about the Geomoose-users mailing list
