[Geomoose-users] identify maps
    Dieter Lehmann
    dieter.lehmann at hfwu.de
    Mon May 10 15:38:55 EDT 2010
Hi Len,
thanks for your reply. After your answer I looked through my files and found the error - I had a typo within the wms_onlineresource.
Thanks,
Dieter
Am 03.05.2010 um 16:36 schrieb Len Kne:
> If you can post your mapbook and relevant map file, we can take a further look.  The error is referring to the shape GM is sending to do the query.
> Len
> From: Dieter Lehmann [mailto:dieter.lehmann at hfwu.de]
> Sent: Sunday, May 02, 2010 8:39 AM
> To: geomoose-users at lists.sourceforge.net
> Subject: [Geomoose-users] identify maps
> Hello,
> I' m having problems with the identify tool. I'm getting the following error:
> Fatal error: Call to a member function queryByPoint() on a non-object in/var/www//temp/htdocs/php/identify.php on line 125
> With the parcel - demo the identify is no problem.
> Any hints?
> Could the cause somehow be my projection? I'm using wgs84 (epsg:4326) for my application.
> If someone have a cookbook for adding new layers plus identify them that would be great - in the wiki this is  missing for geomoose 2 or at least I couldn't find it.
> Thanks,
> Dieter
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100510/5546f796/attachment.html
More information about the Geomoose-users
