[Geomoose-users] Geomoose-users Digest, Vol 32, Issue 1
Glen D Lee | Wendler glenl at wendlerengineering.com
Sun May 2 14:30:35 EDT 2010
geomoose-users-request at lists.sourceforge.net wrote:
>Send Geomoose-users mailing list submissions to
>	geomoose-users at lists.sourceforge.net
>To subscribe or unsubscribe via the World Wide Web, visit
>	https://lists.sourceforge.net/lists/listinfo/geomoose-users
>or, via email, send a message with subject or body 'help' to
>You can reach the person managing the list at
>	geomoose-users-owner at lists.sourceforge.net
>When replying, please edit your Subject line so it is more specific
>than "Re: Contents of Geomoose-users digest..."
>Today's Topics:
>   1. Re: Map Layer Order (Bob Basques)
>   2. Re: Map Layer Order (Dave Misun)
>   3. Scalebar & Measure (Wirth, Paul)
>Message: 1
>Date: Fri, 30 Apr 2010 12:53:16 -0500
>From: "Bob Basques" <Bob.Basques at ci.stpaul.mn.us>
>Subject: Re: [Geomoose-users] Map Layer Order
>To: "Len Kne" <lkne at houstoneng.com>, "'Dave Misun'"
>	<dmisun at kapur-assoc.com>,	"'geomoose-users at lists.sourceforge.net'"
>	<geomoose-users at lists.sourceforge.net>
>Message-ID: <4BDAD2BC.163B.00A8.0 at ci.stpaul.mn.us>
>Content-Type: text/plain; charset="us-ascii"
>All,
>You might look into setting up a common mapfile for both points and lines, where the Sewers come on in a single layer call.  There are pluses and minuses to this approach, but it does work.
>bobb
>>>> Len Kne <lkne at houstoneng.com> wrote:
>Hi Dave
>Try moving MH below the sewer line layer in the MAP file.  Normally GeoMOOSE will order layers in the same order as the <map-source>, but when more than one layer in a map-source point to the same MAP file, the order is controlled by the MAP file, which is first in first out.
>Len
>From:
>Dave Misun [mailto:dmisun at kapur-assoc.com]
>Sent: Friday, April 30, 2010 11:02 AM
>To: 'geomoose-users at lists.sourceforge.net'
>Subject: [Geomoose-users] Map Layer Order
>Hello Everyone,
>I have a question about layer order on a map, searched the user list and didn't find any previous threads covering this. I have a sewer manhole point layer and a sewer pipe line layer, among others on my map, and the line layer is rendering on top of the point layer. I have the point layer on top of the list in the catalog & map service sections of MAPBOOK, as well as having MH come before pipes in my MAP file, but the pipes continue to render on top of the MHs; all else is correct. What am I overlooking?
>I'm using GM 2.2.
>Any advice is appreciated. Thanks!
>Dave Misun
>-------------- next part --------------
>An HTML attachment was scrubbed...
>Message: 2
>Date: Fri, 30 Apr 2010 13:10:50 -0500
>From: Dave Misun <dmisun at kapur-assoc.com>
>To: 'Len Kne' <lkne at houstoneng.com>,
>Message-ID:
>	<5D6DB2B48B2DB64F91BE36639FE6127B02D3419D59 at mail1.kapur-assoc.com>
>Hi Len,
>It worked. I didn't realize the MAP file was FIFO, I thought it rendered bottom to top, i.e. the last layer in the MAP file was displayed on the bottom, etc.
>Thanks to all for the suggestions.
>Dave Misun
>________________________________
>From: Len Kne [mailto:lkne at houstoneng.com]
>Sent: Friday, April 30, 2010 12:21 PM
>To: Dave Misun; 'geomoose-users at lists.sourceforge.net'
>Subject: RE: Map Layer Order
>Hi Dave
>Len
>From: Dave Misun [mailto:dmisun at kapur-assoc.com]
>Hello Everyone,
>I'm using GM 2.2.
>Dave Misun
>Message: 3
>Date: Sat, 1 May 2010 21:02:31 -0500
>From: "Wirth, Paul" <Paul.Wirth at kniferiver.com>
>Subject: [Geomoose-users] Scalebar & Measure
>To: "'geomoose-users at lists.sourceforge.net'"
>Message-ID:
>	<384542C47F22DF4FB0312A86E40E6B49CB7853A228 at MDUREX02.mdu.com>
>Two questions:
>1.      I have a web Mercator application, and I noticed that the scalebar does not display the correct distance.  For instance, when the scalebar shows a distance of 20 miles, it measures only 13.8 miles.  I know the measure tools are working correctly, so I assume this is a scalebar issue.  Any thoughts on how to fix this?
>2.      I think this question was asked before, but I can't seem to find it on the e-mail list.  With the measure tools, the cursor does not start measuring at the "crosshairs" when the user clicks, but rather in the NW quadrant of the crosshairs.  Is there a way to change it so the measure start point will be on the crosshairs?
>_______________________________________________
>Geomoose-users at lists.sourceforge.net
>End of Geomoose-users Digest, Vol 32, Issue 1
More information about the Geomoose-users mailing list
