[Geomoose-users] Geomoose-users Digest, Vol 32, Issue 1
Dan Little danlittle at yahoo.com
Mon May 3 09:27:17 EDT 2010
Glen,
I'm a bit lazy.  Can you pull your question out into a separate thread on the Mailing List? Thanks!
----- Original Message ----
> From: Glen D Lee | Wendler <glenl at wendlerengineering.com>
> To: geomoose-users at lists.sourceforge.net
> Sent: Sun, May 2, 2010 1:30:35 PM
> Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 32, Issue 1
> href="mailto:geomoose-users-request at lists.sourceforge.net">geomoose-users-request at lists.sourceforge.net
> wrote:
>Send Geomoose-users mailing list submissions
> to
> ymailto="mailto:geomoose-users at lists.sourceforge.net"
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net
>To
> subscribe or unsubscribe via the World Wide Web, visit
> target=_blank
> >https://lists.sourceforge.net/lists/listinfo/geomoose-users
>or, via
> email, send a message with subject or body 'help' to
>You
> can reach the person managing the list at
> ymailto="mailto:geomoose-users-owner at lists.sourceforge.net"
> href="mailto:geomoose-users-owner at lists.sourceforge.net">geomoose-users-owner at lists.sourceforge.net
>When
> replying, please edit your Subject line so it is more specific
>than "Re:
> Contents of Geomoose-users digest..."
>Today's
> Topics:
>   1. Re: Map Layer Order (Bob
> Basques)
>   2. Re: Map Layer Order (Dave Misun)
>   3.
> Scalebar & Measure (Wirth,
> Paul)
>Message:
> 1
>Date: Fri, 30 Apr 2010 12:53:16 -0500
>From: "Bob Basques" <
> ymailto="mailto:Bob.Basques at ci.stpaul.mn.us"
> href="mailto:Bob.Basques at ci.stpaul.mn.us">Bob.Basques at ci.stpaul.mn.us>
>Subject:
> Re: [Geomoose-users] Map Layer Order
>To: "Len Kne" <
> ymailto="mailto:lkne at houstoneng.com"
> href="mailto:lkne at houstoneng.com">lkne at houstoneng.com>, "'Dave
> Misun'"
> href="mailto:dmisun at kapur-assoc.com">dmisun at kapur-assoc.com>,
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net'"
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net>
>Message-ID:
> href="mailto:4BDAD2BC.163B.00A8.0 at ci.stpaul.mn.us">4BDAD2BC.163B.00A8.0 at ci.stpaul.mn.us>
>Content-Type:
> text/plain; charset="us-ascii"
>All,
>You might
> look into setting up a common mapfile for both points and lines, where the
> Sewers come on in a single layer call.  There are pluses and minuses to
> this approach, but it does work.
>bobb
>>>> Len Kne <
> wrote:
>Hi Dave
>Try moving MH below the sewer line layer in the MAP
> file.  Normally GeoMOOSE will order layers in the same order as the
> <map-source>, but when more than one layer in a map-source point to the
> same MAP file, the order is controlled by the MAP file, which is first in first
> out.
>Len
>From:
>Dave Misun [mailto:
> ymailto="mailto:dmisun at kapur-assoc.com"
> href="mailto:dmisun at kapur-assoc.com">dmisun at kapur-assoc.com]
>Sent:
> Friday, April 30, 2010 11:02 AM
>To: '
>Subject:
>Hello Everyone,
>I have a question about layer order on a map, searched
> the user list and didn't find any previous threads covering this. I have a sewer
> manhole point layer and a sewer pipe line layer, among others on my map, and the
> line layer is rendering on top of the point layer. I have the point layer on top
> of the list in the catalog & map service sections of MAPBOOK, as well as
> having MH come before pipes in my MAP file, but the pipes continue to render on
> top of the MHs; all else is correct. What am I overlooking?
>I'm using GM 2.2.
>Any advice is
> appreciated. Thanks!
>Dave Misun
>-------------- next part
>An HTML attachment was
> scrubbed...
>Message:
> 2
>Date: Fri, 30 Apr 2010 13:10:50 -0500
>From: Dave Misun <
>Subject:
>To: 'Len Kne' <
>Message-ID:
> ymailto="mailto:5D6DB2B48B2DB64F91BE36639FE6127B02D3419D59 at mail1.kapur-assoc.com"
> href="mailto:5D6DB2B48B2DB64F91BE36639FE6127B02D3419D59 at mail1.kapur-assoc.com">5D6DB2B48B2DB64F91BE36639FE6127B02D3419D59 at mail1.kapur-assoc.com>
>Content-Type:
>Hi Len,
>It worked.
> I didn't realize the MAP file was FIFO, I thought it rendered bottom to top,
> i.e. the last layer in the MAP file was displayed on the bottom,
> etc.
>Thanks to all for the suggestions.
>Dave
> Misun
>________________________________
>From: Len
> Kne [mailto:
> href="mailto:lkne at houstoneng.com">lkne at houstoneng.com]
>Sent: Friday,
> April 30, 2010 12:21 PM
>To: Dave Misun; '
>Subject:
> RE: Map Layer Order
>Hi Dave
>Try moving MH below
> the sewer line layer in the MAP file.  Normally GeoMOOSE will order layers
> in the same order as the <map-source>, but when more than one layer in a
> map-source point to the same MAP file, the order is controlled by the MAP file,
> which is first in first out.
>Len
>From:
> Dave Misun [mailto:
>Sent:
>To: '
>Subject:
>Hello Everyone,
>I
> have a question about layer order on a map, searched the user list and didn't
> find any previous threads covering this. I have a sewer manhole point layer and
> a sewer pipe line layer, among others on my map, and the line layer is rendering
> on top of the point layer. I have the point layer on top of the list in the
> catalog & map service sections of MAPBOOK, as well as having MH come before
> pipes in my MAP file, but the pipes continue to render on top of the MHs; all
>I'm using GM
> 2.2.
>Any advice is appreciated. Thanks!
>Dave
> Misun
>-------------- next part --------------
>An HTML
> attachment was
> scrubbed...
>Message:
> 3
>Date: Sat, 1 May 2010 21:02:31 -0500
>From: "Wirth, Paul" <
> ymailto="mailto:Paul.Wirth at kniferiver.com"
> href="mailto:Paul.Wirth at kniferiver.com">Paul.Wirth at kniferiver.com>
>Subject:
> [Geomoose-users] Scalebar & Measure
>To: "'
>Message-ID:
> ymailto="mailto:384542C47F22DF4FB0312A86E40E6B49CB7853A228 at MDUREX02.mdu.com"
> href="mailto:384542C47F22DF4FB0312A86E40E6B49CB7853A228 at MDUREX02.mdu.com">384542C47F22DF4FB0312A86E40E6B49CB7853A228 at MDUREX02.mdu.com>
>Content-Type:
>Two
> questions:
>1.      I have a web Mercator
> application, and I noticed that the scalebar does not display the correct
> distance.  For instance, when the scalebar shows a distance of 20 miles, it
> measures only 13.8 miles.  I know the measure tools are working correctly,
> so I assume this is a scalebar issue.  Any thoughts on how to fix
> this?
>2.      I think this question was asked
> before, but I can't seem to find it on the e-mail list.  With the measure
> tools, the cursor does not start measuring at the "crosshairs" when the user
> clicks, but rather in the NW quadrant of the crosshairs.  Is there a way to
> change it so the measure start point will be on the
> crosshairs?
>An HTML
> attachment was
> scrubbed...
>_______________________________________________
>Geomoose-users
> mailing list
> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lists.sourceforge.net
> href="https://lists.sourceforge.net/lists/listinfo/geomoose-users" target=_blank
>End
> of Geomoose-users Digest, Vol 32, Issue
> 1
Geomoose-users
> mailing list
More information about the Geomoose-users mailing list
