[Geomoose-users] Scale issue
Dan Little
danlittle at yahoo.com
Fri May 14 11:19:44 EDT 2010
Yeah, IIRC, points are buffered by some arbitrary amount (I want to say 200 ft or meters) and then zoomed to that extent. I assume you're using the itemquery code, so if you dig in that PHP script you should see a line buffering points.
>From: "Wirth, Paul" <Paul.Wirth at kniferiver.com>
>To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Fri, May 14, 2010 9:44:22 AM
>Subject: [Geomoose-users] Scale issue
>Hey Everybody,
>I am using Geomoose 2.2 Webmercator to map out our
>properties over 5 states. One issue that I am having is I am searching our
>properties by point and it jumps to a scale of 1:864 all the time for points. I
>have tried some things, but have been able to change the jumpto_scale to bring
>up a bigger scale so I can view the property boundaries. A 1:10000 scale would
>work better and then I can zoom in from there. Anybody have any ideas.
>Paul Wirth
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100514/890fd7de/attachment.html
More information about the Geomoose-users
