[Geomoose-users] Scale issue
FRANZ OKYERE franzzoa at hotmail.com
Fri May 14 11:22:07 EDT 2010
 Hi Paul,
What I suggest you set the MINSCALEDENOM for the layer you are searching and adjust. All things being equal you be able to zoom to the scale you want on search. The other thing you might have to do is to have a look at the query.php(?) controlling the searching- the porting of the code where the zooming happens and then again do some customisation.
Hope this helps
Franz
To: geomoose-users at lists.sourceforge.net
Date: Fri, 14 May 2010 09:44:22 -0500
Subject: [Geomoose-users] Scale issue
Hey Everybody,
I am using Geomoose 2.2 Webmercator to map out our properties over 5 states. One issue that I am having is I am searching our properties by point and it jumps to a scale of 1:864 all the time for points. I have tried some things, but have been able to change the jumpto_scale to bring up a bigger scale so I can view the property boundaries. A 1:10000 scale would work better and then I can zoom in from there. Anybody have any ideas.
Paul Wirth
_________________________________________________________________
http://clk.atdmt.com/UKM/go/197222280/direct/01/
Do you have a story that started on Hotmail? Tell us now
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100514/0a8abe58/attachment.html
More information about the Geomoose-users mailing list
