[Geomoose-users] Geocode and Identify Errors
Brent Fraser
bfraser at geoanalytic.com
Wed May 26 12:21:09 EDT 2010
Strange. There was only one layer in the map file you sent. Can you send the
entire URL from the get request?
Wes Cleland wrote:
> I just for some reason decided to turn off all layers except the layer I
> want to identify, it works! But when I turn the other layers back on, it
> doesn't work...
> v/r,
> Wesley T. Cleland, GISP, CFM
> GIS Coordinator
> City of Van Buren, Arkansas
> 479-471-5025
> "One ought never to turn one's back on a threatened danger and try to
> run away from it. If you do that, you will double the danger. But if you
> meet it promptly and without flinching, you will reduce the danger by
> half. Never run away from anything. Never!"
> Winston Churchill
> -----Original Message-----
> From: bfraser at geoanalytic.com [mailto:bfraser at geoanalytic.com]
> Sent: Wednesday, May 26, 2010 10:03 AM
> To: Wes Cleland
> Cc: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Geocode and Identify Errors
> Wes,
> There could be a few reasons:
> 1. The layer is not searchable (it requires a TEMPLATE in the map file,
> or for
> GM 2, an "identify_record" entry in the METADATA section of the map
> file. And I
> think the "identify_record" file must exist.
> 2. Coordinate system issues. Is the map file PROJECTION and the LAYER
> PROJECTION set properly?
> Brent
> Wes Cleland wrote:
>> I installed firefox with firebug on my windows machine (this is the
>> machine I have been testing the site with) and I believe I have
> isolated
>> the error. On the right side it gives me OpenLayers.js line 1103, on
> the
>> left is says
>> GET http://gis-svr/geomoose2/php/identify.php?layers(and then it shows
>> the layers and the shape I used to identify the
>> point)&_moosetime=1274883453837
>> no element found
>> I am not good at this, but I believe it is telling me that even though
>> it is searching through all the layers that are turned on, it is not
>> finding something in particular it needs to show the files.
>> If I take the original mapbook and create a shapefile from my postgis
>> database named parcels.shp and replace the original parcels file, it
>> gives me the error. It is only working with the original data.
>> v/r,
>> GIS Coordinator
>> 479-471-5025
> you
>> Winston Churchill
>> Sent: Tuesday, May 25, 2010 11:28 AM
>> To: Wes Cleland
>> looks ok. is your web site accessible to the outside world? Can you
>> send me
>> the URL?
>> Wes Cleland wrote:
>>> Brent,
>>> <param name="mapfile_root">/opt/geomoose2/maps/</param>
>>> <map-source name="parcels" type="mapserver" reference="false">
>>> <file>./vanburen/landrecords/parcels_postgis.map</file>
>>> <layer name="parcels"/>
>>> </map-source>
>>> METADATA
>>> "identify_record" "identify_parcel.html"
>>> "select_record" "select_parcel.html"
>>> "select_header" "select_header_parcels.html"
>>> "popups" "parcels_popup.html"
>>> "itemquery" "parcels_itemquery.html"
>>> qstring_validation_pattern '.'
>>> # Feature reports are stored in the conf/feature_report
>>> directory.
>>> "feature_report" "parcel.xml"
>>> END
>>> v/r,
>>> GIS Coordinator
>>> 479-471-5025
>> you
>>> Winston Churchill
>>> From: Brent Fraser <bfraser at geoanalytic.com>
>>> Date: Tue, 25 May 2010 09:25:16
>>> To: Wes Cleland<wcleland at vanburencity.org>
>>> Cc: <geomoose-users at lists.sourceforge.net>
>>> Wes,
>>> Sounds like a file name, path(most likely), or permissions
> problem.
>>> What does your mapfile_root and <map-source> for your data look like?
>>> For
>>> example, mine is:
>>> <param name="mapfile_root">/MS4W30b11/apps/MyApp/maps/</param>
>>> <map-source name="Basins" type="mapserver" default="false"
>>> reference="false">
>>> <file>./Pathfinder/Basins.map</file>
>>> <layer name="Basins"/>
>>> </map-source>
>>> With the following in the Basins.map file:
>>> METADATA
>>> 'wms_title' 'Basins'
>>> "identify_record" "basins.html"
>>> END
>>> Where basins.html is in the same directory as the Basins.map file.
>>> And the php.ini entry in the previous email was taken from the one
>>> delivered
>>> with MS4W's PHP so I'm assuming it's ok.
>>> Best Regards,
>>> Brent Fraser
>>> Wes Cleland wrote:
>>>> Brent,
>>>> Here is where I stand after bashing my head into my computer screen
>>>> yesterday. If I take the original mapbook.xml, and use the identify
>>> tool
>>>> with the original demo data, it works. If I change the settings.ini
>>> file
>>>> to read my new mapbook, I get the error. If I take the original
>>> mapbook,
>>>> and alter the coordinates then replace the original data with my
>> data,
>>>> it works. There is some configuration that is telling it to read the
>>>> path /maps/demo/landrecords. I attempted to change the php5.ini file
>>> and
>>>> when I restart the server, it defaults to the original configuration
>>> (I
>>>> am assuming this is lack of experience). Also, I did not see the
>> value
>>>> 22519 in the link you provided. Thanks for the help!
>>>> v/r,
>>>> GIS Coordinator
>>>> 479-471-5025
> to
>>> you
> by
>>>> Winston Churchill
>>>> Date: Tue, 25 May 2010 08:17:15
>>>> To: <wescleland at hotmail.com>
>>>> Wes,
>>>> It looks like there's several ways to fix this, the easiest (and
>>>> best?) being
>>>> to set the error reporting level in the php.ini file to:
>>>> error_reporting = 22519 ;see values in
>>>> http://ca2.php.net/manual/en/errorfunc.constants.php (all errors
>> minus
>>>> notices
>>>> and deprecated)
>>>> Best Regards,
>>>> Brent Fraser
>>>> wescleland at hotmail.com wrote:
>>>>> I will look into this and see, I just copied the folders from the
>>> ms4w
>>>> folder so that could be missing something. The funny thing is, at
> the
>>>> bottom of the errors, it has the print links and they work.
>>>>> Sent on the Sprint(r) Now Network from my BlackBerry(r)
>>>>> From: "Brent Fraser" <bfraser at geoanalytic.com>
>>>>> Date: Fri, 21 May 2010 18:16:13
>>>>> Wes,
>>>>> I was thinking of the FPDI PDF file "template" (the PDF files in
>>>>> Geomoose/conf/print), not the Mapserver results HTML "template". I
>>>>> haven't done much with printing in GM 2, but its likely that there
>>> are
>>>>> some restrictions as to the version of PDF and kinds/arrangement of
>>>>> elements inside the PDF templates.
>>>>> Brent
>>>>>> I am using a custom template that was created and implemented in
>>> ms4w
>>>>>> 2.3.1, there was no errors when using ms4w only when I switched to
>>>>>> linux/FGS9.5. As well I am not at the office this moment, so I
>> don't
>>>> know
>>>>>> the exact version of php, but I believe it is php5.3.something,
>>>> whichever
>>>>>> version is in the most current version of fgs9.5.
>>>>>> Thanks for the help.
>>>>>> Wes
>>>>>> Date: Fri, 21 May 2010 16:05:44
>>>>>> For the printing errors, it looks like its having problems with
> the
>>>>>> template PDF
>>>>>> file. Is it the same as with the demo data or did you edit it?
>>>>>> Which version of PHP are you using?
>>>>>> Best Regards,
>>>>>> Brent Fraser
>>>>>> Wes Cleland wrote:
>>>>>>> This is the error when attempting to print:
>>>>>>> *Deprecated*: Assigning the return value of new by reference is
>>>>>>> deprecated in */opt/geomoose2/htdocs/php/fpdi/fpdi.php* on line
>>> *88*
>>>>>>> deprecated in
> */opt/geomoose2/htdocs/php/fpdi/fpdi_pdf_parser.php*
>>>> on
>>>>>>> line *244*
>>>>>>> deprecated in */opt/geomoose2/htdocs/php/fpdi/pdf_parser.php* on
>>>> line
>>>>>>> *102*
>>>> line
>>>>>>> *285*
>>>> line
>>>>>>> *437*
>>>>>>> *Warning*: Cannot modify header information - headers already
> sent
>>>> by
>>>>>>> (output started at /opt/geomoose2/htdocs/php/fpdi/fpdi.php:88) in
>>>>>>> */opt/geomoose2/htdocs/php/print.php* on line *136*
>>>>>>> The identify error is this:
>>>>>>> As previously stated, I can load the default mapbook.xml with the
>>>> demo
>>>>>>> data and the identify/select/buffer/search works fine, but when I
>>>> load
>>>>>>> the mapbook created with my data it gives me these errors. I even
>>>> went
>>>>>>> as far as rebuilding the mapbook ensuring that every little word
>>> was
>>>>>>> typed correctly/etc.
>>>>>>> v/r,
>>>>>>> GIS Coordinator
>>>>>>> 479-471-5025
> try
>>>> to
>>> if
>>>> you
> danger
>>>> by
>>>>>>> Winston Churchill
>>>>>>> *From:* danlittle at yahoo.com [mailto:danlittle at yahoo.com]
>>>>>>> *Sent:* Friday, May 21, 2010 8:21 AM
>>>>>>> *To:* wcleland at vanburencity.org
>>>>>>> *Subject:* Re: [Geomoose-users] Geocode and Identify Errors
>>>>>>> I'd suggest two things:
>>>>>>> 1) File a bug in Trac.
>>>>>>> 2) Edit both geocode.php and identify.php files and replace
>> "split"
>>>> with
>>>>>>> "explode". PHP does obnoxiously stupid things with strings and
>>>> string
>>>>>>> functions.
>>>>>>> *From:* Wes Cleland <wcleland at vanburencity.org>
>>>>>>> *To:* geomoose-users at lists.sourceforge.net
>>>>>>> *Sent:* Thu, May 20, 2010 4:04:06 PM
>>>>>>> *Subject:* [Geomoose-users] Geocode and Identify Errors
>>>>>>> First off, I would like to say thanks for the assistance;
>> these
>>>>>>> mailing list are worth their weight in gold when it comes to
>>>>>>> someone
>>>>>>> just starting out in a program such as myself. I started off
>>>> using
>>>>>>> MS4W and GeoMoose and after an abundance of use, was
>> authorized
>>>> to
>>>>>>> move to a server. Due to funding issues Linux was the best
>>> route
>>>> to
>>>>>>> go. So I am not only learning more about GeoMoose, I am
>>> learning
>>>>>>> linux as well. After some configuration and permission
> issues,
>>> I
>>>>>>> finally was able to get GeoMoose to display in a web browser
>>>> using
>>>>>>> FGS9.5 on linux. I can pan, zoom-in, etc., however, when I
>>>> search,
>>>>>>> identify, geocode, and print I get an error. Usually along
> the
>>>> lines
>>>>>>> of:
>>>>>>> *Deprecated*: Function split() is deprecated in
>>>>>>> */opt/geomoose2/htdocs/php/geocode.php* on line *22*
>>>> sent
>>>>>>> by (output started at
>> /opt/geomoose2/htdocs/php/geocode.php:22)
>>>> in
>>>>>>> */opt/geomoose2/htdocs/php/geocode.php* on line *27*
>>>>>>> This particular error is specific to geocoding obviously, but
>>>> they
>>>>>>> all contain the word deprecated and end in cannot modify
>> header
>>>>>>> information. When I attempt to identify, select, buffer I get
>>> an
>>>>>>> unhandled request return Unknown error. I am stuck and any
>>>>>>> assistance would be greatly appreciated. Thanks in advance.
>>>>>>> v/r,
>>>>>>> Wes Cleland
>>>>>>> _______________________________________________
>>>>>>> Geomoose-users mailing list
>>>>>>> Geomoose-users at lists.sourceforge.net
>>>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
