[Geomoose-users] Geocode and Identify Errors
Wes Cleland
wcleland at vanburencity.org
Wed May 26 13:43:48 EDT 2010
Ok, so now that I have completely run through the list like banshee, I
figured out that there was 8 mapfiles I had that did not match the
parcels layer. I altered all the mapfiles so that the top portion of the
mapfile was the same as the parcel. Then verified that all my mapfiles
were the same, after this everything works. Apparently there was
something inside the mapfile that it did not like and was throwing an
error. Thanks to everyone for all the help with this problem!!!!!
v/r,
Wesley T. Cleland, GISP, CFM
GIS Coordinator
City of Van Buren, Arkansas
479-471-5025
"One ought never to turn one's back on a threatened danger and try to
run away from it. If you do that, you will double the danger. But if you
meet it promptly and without flinching, you will reduce the danger by
half. Never run away from anything. Never!"
Winston Churchill
-----Original Message-----
From: bfraser at geoanalytic.com [mailto:bfraser at geoanalytic.com]
Sent: Wednesday, May 26, 2010 11:21 AM
To: Wes Cleland
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Geocode and Identify Errors
Strange. There was only one layer in the map file you sent. Can you
send the
entire URL from the get request?
Wes Cleland wrote:
> I just for some reason decided to turn off all layers except the layer
I
> want to identify, it works! But when I turn the other layers back on,
it
> doesn't work...
> v/r,
> GIS Coordinator
> 479-471-5025
you
> Winston Churchill
> Sent: Wednesday, May 26, 2010 10:03 AM
> To: Wes Cleland
> Wes,
> There could be a few reasons:
> 1. The layer is not searchable (it requires a TEMPLATE in the map
file,
> or for
> GM 2, an "identify_record" entry in the METADATA section of the map
> file. And I
> think the "identify_record" file must exist.
> 2. Coordinate system issues. Is the map file PROJECTION and the LAYER
> PROJECTION set properly?
> Brent
> Wes Cleland wrote:
>> I installed firefox with firebug on my windows machine (this is the
>> machine I have been testing the site with) and I believe I have
> isolated
>> the error. On the right side it gives me OpenLayers.js line 1103, on
> the
>> left is says
>> GET http://gis-svr/geomoose2/php/identify.php?layers(and then it
shows
>> the layers and the shape I used to identify the
>> point)&_moosetime=1274883453837
>> no element found
>> I am not good at this, but I believe it is telling me that even
though
>> it is searching through all the layers that are turned on, it is not
>> finding something in particular it needs to show the files.
>> If I take the original mapbook and create a shapefile from my postgis
>> database named parcels.shp and replace the original parcels file, it
>> gives me the error. It is only working with the original data.
>> v/r,
>> GIS Coordinator
>> 479-471-5025
> you
>> Winston Churchill
>> Sent: Tuesday, May 25, 2010 11:28 AM
>> To: Wes Cleland
>> looks ok. is your web site accessible to the outside world? Can you
>> send me
>> the URL?
>> Wes Cleland wrote:
>>> Brent,
>>> <param name="mapfile_root">/opt/geomoose2/maps/</param>
>>> <map-source name="parcels" type="mapserver" reference="false">
>>> <file>./vanburen/landrecords/parcels_postgis.map</file>
>>> <layer name="parcels"/>
>>> </map-source>
>>> METADATA
>>> "identify_record" "identify_parcel.html"
>>> "select_record" "select_parcel.html"
>>> "select_header" "select_header_parcels.html"
>>> "popups" "parcels_popup.html"
>>> "itemquery" "parcels_itemquery.html"
>>> qstring_validation_pattern '.'
>>> # Feature reports are stored in the conf/feature_report
>>> directory.
>>> "feature_report" "parcel.xml"
>>> END
>>> v/r,
>>> GIS Coordinator
>>> 479-471-5025
to
>> you
by
>>> Winston Churchill
>>> From: Brent Fraser <bfraser at geoanalytic.com>
>>> Date: Tue, 25 May 2010 09:25:16
>>> To: Wes Cleland<wcleland at vanburencity.org>
>>> Cc: <geomoose-users at lists.sourceforge.net>
>>> Wes,
>>> Sounds like a file name, path(most likely), or permissions
> problem.
>>> What does your mapfile_root and <map-source> for your data look
like?
>>> For
>>> example, mine is:
>>> <param name="mapfile_root">/MS4W30b11/apps/MyApp/maps/</param>
>>> <map-source name="Basins" type="mapserver" default="false"
>>> reference="false">
>>> <file>./Pathfinder/Basins.map</file>
>>> <layer name="Basins"/>
>>> </map-source>
>>> With the following in the Basins.map file:
>>> METADATA
>>> 'wms_title' 'Basins'
>>> "identify_record" "basins.html"
>>> END
>>> Where basins.html is in the same directory as the Basins.map file.
>>> And the php.ini entry in the previous email was taken from the one
>>> delivered
>>> with MS4W's PHP so I'm assuming it's ok.
>>> Best Regards,
>>> Brent Fraser
>>> Wes Cleland wrote:
>>>> Brent,
>>>> Here is where I stand after bashing my head into my computer screen
>>>> yesterday. If I take the original mapbook.xml, and use the identify
>>> tool
>>>> with the original demo data, it works. If I change the settings.ini
>>> file
>>>> to read my new mapbook, I get the error. If I take the original
>>> mapbook,
>>>> and alter the coordinates then replace the original data with my
>> data,
>>>> it works. There is some configuration that is telling it to read
the
>>>> path /maps/demo/landrecords. I attempted to change the php5.ini
file
>>> and
>>>> when I restart the server, it defaults to the original
configuration
>>> (I
>>>> am assuming this is lack of experience). Also, I did not see the
>> value
>>>> 22519 in the link you provided. Thanks for the help!
>>>> v/r,
>>>> GIS Coordinator
>>>> 479-471-5025
> to
if
>>> you
> by
>>>> Winston Churchill
>>>> Date: Tue, 25 May 2010 08:17:15
>>>> To: <wescleland at hotmail.com>
>>>> Wes,
>>>> It looks like there's several ways to fix this, the easiest (and
>>>> best?) being
>>>> to set the error reporting level in the php.ini file to:
>>>> error_reporting = 22519 ;see values in
>>>> http://ca2.php.net/manual/en/errorfunc.constants.php (all errors
>> minus
>>>> notices
>>>> and deprecated)
>>>> Best Regards,
>>>> Brent Fraser
>>>> wescleland at hotmail.com wrote:
>>>>> I will look into this and see, I just copied the folders from the
>>> ms4w
>>>> folder so that could be missing something. The funny thing is, at
> the
>>>> bottom of the errors, it has the print links and they work.
>>>>> Sent on the Sprint(r) Now Network from my BlackBerry(r)
>>>>> From: "Brent Fraser" <bfraser at geoanalytic.com>
>>>>> Date: Fri, 21 May 2010 18:16:13
>>>>> Wes,
>>>>> I was thinking of the FPDI PDF file "template" (the PDF files in
>>>>> Geomoose/conf/print), not the Mapserver results HTML "template".
I
>>>>> haven't done much with printing in GM 2, but its likely that there
>>> are
>>>>> some restrictions as to the version of PDF and kinds/arrangement
of
>>>>> elements inside the PDF templates.
>>>>> Brent
>>>>>> I am using a custom template that was created and implemented in
>>> ms4w
>>>>>> 2.3.1, there was no errors when using ms4w only when I switched
to
>>>>>> linux/FGS9.5. As well I am not at the office this moment, so I
>> don't
>>>> know
>>>>>> the exact version of php, but I believe it is php5.3.something,
>>>> whichever
>>>>>> version is in the most current version of fgs9.5.
>>>>>> Thanks for the help.
>>>>>> Wes
>>>>>> Date: Fri, 21 May 2010 16:05:44
>>>>>> For the printing errors, it looks like its having problems with
> the
>>>>>> template PDF
>>>>>> file. Is it the same as with the demo data or did you edit it?
>>>>>> Which version of PHP are you using?
>>>>>> Best Regards,
>>>>>> Brent Fraser
>>>>>> Wes Cleland wrote:
>>>>>>> This is the error when attempting to print:
>>>>>>> *Deprecated*: Assigning the return value of new by reference is
>>>>>>> deprecated in */opt/geomoose2/htdocs/php/fpdi/fpdi.php* on line
>>> *88*
>>>>>>> deprecated in
> */opt/geomoose2/htdocs/php/fpdi/fpdi_pdf_parser.php*
>>>> on
>>>>>>> line *244*
>>>>>>> deprecated in */opt/geomoose2/htdocs/php/fpdi/pdf_parser.php* on
>>>> line
>>>>>>> *102*
>>>> line
>>>>>>> *285*
>>>> line
>>>>>>> *437*
>>>>>>> *Warning*: Cannot modify header information - headers already
> sent
>>>> by
>>>>>>> (output started at /opt/geomoose2/htdocs/php/fpdi/fpdi.php:88)
in
>>>>>>> */opt/geomoose2/htdocs/php/print.php* on line *136*
>>>>>>> The identify error is this:
>>>>>>> As previously stated, I can load the default mapbook.xml with
the
>>>> demo
>>>>>>> data and the identify/select/buffer/search works fine, but when
I
>>>> load
>>>>>>> the mapbook created with my data it gives me these errors. I
even
>>>> went
>>>>>>> as far as rebuilding the mapbook ensuring that every little word
>>> was
>>>>>>> typed correctly/etc.
>>>>>>> v/r,
>>>>>>> GIS Coordinator
>>>>>>> 479-471-5025
> try
>>>> to
But
>>> if
>>>> you
> danger
>>>> by
>>>>>>> Winston Churchill
>>>>>>> *From:* danlittle at yahoo.com [mailto:danlittle at yahoo.com]
>>>>>>> *Sent:* Friday, May 21, 2010 8:21 AM
>>>>>>> *To:* wcleland at vanburencity.org
>>>>>>> *Subject:* Re: [Geomoose-users] Geocode and Identify Errors
>>>>>>> I'd suggest two things:
>>>>>>> 1) File a bug in Trac.
>>>>>>> 2) Edit both geocode.php and identify.php files and replace
>> "split"
>>>> with
>>>>>>> "explode". PHP does obnoxiously stupid things with strings and
>>>> string
>>>>>>> functions.
>>>>>>> *From:* Wes Cleland <wcleland at vanburencity.org>
>>>>>>> *To:* geomoose-users at lists.sourceforge.net
>>>>>>> *Sent:* Thu, May 20, 2010 4:04:06 PM
>>>>>>> *Subject:* [Geomoose-users] Geocode and Identify Errors
>>>>>>> First off, I would like to say thanks for the assistance;
>> these
>>>>>>> mailing list are worth their weight in gold when it comes to
>>>>>>> someone
>>>>>>> just starting out in a program such as myself. I started off
>>>> using
>>>>>>> MS4W and GeoMoose and after an abundance of use, was
>> authorized
>>>> to
>>>>>>> move to a server. Due to funding issues Linux was the best
>>> route
>>>> to
>>>>>>> go. So I am not only learning more about GeoMoose, I am
>>> learning
>>>>>>> linux as well. After some configuration and permission
> issues,
>>> I
>>>>>>> finally was able to get GeoMoose to display in a web browser
>>>> using
>>>>>>> FGS9.5 on linux. I can pan, zoom-in, etc., however, when I
>>>> search,
>>>>>>> identify, geocode, and print I get an error. Usually along
> the
>>>> lines
>>>>>>> of:
>>>>>>> *Deprecated*: Function split() is deprecated in
>>>>>>> */opt/geomoose2/htdocs/php/geocode.php* on line *22*
already
>>>> sent
>>>>>>> by (output started at
>> /opt/geomoose2/htdocs/php/geocode.php:22)
>>>> in
>>>>>>> */opt/geomoose2/htdocs/php/geocode.php* on line *27*
>>>>>>> This particular error is specific to geocoding obviously,
but
>>>> they
>>>>>>> all contain the word deprecated and end in cannot modify
>> header
>>>>>>> information. When I attempt to identify, select, buffer I
get
>>> an
>>>>>>> unhandled request return Unknown error. I am stuck and any
>>>>>>> assistance would be greatly appreciated. Thanks in advance.
>>>>>>> v/r,
>>>>>>> Wes Cleland
>>>>>>> _______________________________________________
>>>>>>> Geomoose-users mailing list
>>>>>>> Geomoose-users at lists.sourceforge.net
>>>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
