[Geomoose-users] Geomoose 2 installation in fgs 9.5 / ubuntu
Wes Cleland
wcleland at vanburencity.org
Thu May 27 09:37:02 EDT 2010
Mark,
This can be very tedious, and I have fought through everything switching
from ms4w to Ubuntu 10.04 with FGS9.5. The easiest way to fix the
problem is to go into terminal, and type the gksudo nautilus command,
navigate to the folder geomoose2 (I assume it is in /opt/geomoose/),
right-click, click the permissions tab, then change all the permissions
to read and the user group to apache. In a development environment it
can be easier for you to change them all to read/write, but some believe
this is a security risk.
The reason you cannot view the actual map and only the skin, you do not
have access to the mapbook. Once that is fixed then you will be able to
view.
v/r,
Wesley T. Cleland, GISP, CFM
GIS Coordinator
City of Van Buren, Arkansas
479-471-5025
"One ought never to turn one's back on a threatened danger and try to
run away from it. If you do that, you will double the danger. But if you
meet
it promptly and without flinching, you will reduce the danger by half.
Never run away from anything. Never!"
Winston Churchill
Hello,
I am having trouble getting GeoMoose 2 to run over FGS on Ubuntu linuix
10.
The FGS software appears to be working fine (the GMAP demo works
flawlessly).
Unfortunately when I attempted to run GeoMoose, the green template from
the
demo shows up, however no layers or tools work. Firebug reported issues
while loading getmapbook.php
<br />
<b>Warning</b>: dl() [<a href='function.dl'>function.dl</a>]: Unable to
load
dynamic library '/opt/fgs/www/lib/php5/php_curl.so' -
/opt/fgs/www/lib/php5/php_curl.so: cannot open shared object file: No
such
file or directory in
<b>/opt/fgs/apps/geomoose2/htdocs/php/config.php</b> on
line <b>41</b><br />
<br />
I noticed that there is no file called /opt/fgs/www/lib/php/config.php,
however the is a file called php_mapscript_5.4.2
What would my next steps be to get GeoMoose up and running?
Thanks
Mark Volz
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100527/48ac1a13/attachment.html
More information about the Geomoose-users
