[Geomoose-users] Geomoose 2 installation in fgs 9.5 / ubuntu
Dan Little danlittle at yahoo.com
Thu May 27 11:33:06 EDT 2010
Nah, the error Mark is seeing is because the PHP installation is not complete.
Startup whatever Ubuntu has as a package manager (I use Debian and OS/X ... sorry) and see if there is a module for php_curl.
>From: Wes Cleland <wcleland at vanburencity.org>
>To: geomoose-users at lists.sourceforge.net
>Sent: Thu, May 27, 2010 8:37:02 AM
>Subject: Re: [Geomoose-users] Geomoose 2 installation in fgs 9.5 / ubuntu
>Mark,
>This can be very tedious, and I have fought through everything
>switching from ms4w to Ubuntu 10.04 with FGS9.5.  The easiest way to fix the
>problem is to go into terminal, and type the gksudo nautilus command, navigate
>to the folder geomoose2 (I assume it is in /opt/geomoose/), right-click, click
>the permissions tab, then change all the permissions to read and the user group
>to apache. In a development environment it can be easier for you to change them
>all to read/write, but some believe this is a security risk.
>The reason you cannot view the actual map and only the
>skin, you do not have access to the mapbook. Once that is fixed then you will
>be able to view.
>v/r,
> Wesley T. Cleland, GISP, CFM
> GIS Coordinator
> City of Van Buren, Arkansas
> 479-471-5025
> "One ought never to turn one's back on a threatened
>danger and try to run away from it. If you do that, you will double the danger.
>But if you meet
>  it promptly and without flinching, you will reduce the
>danger by half. Never run away from anything. Never!"
>  Winston Churchill
>Hello,
>I am having trouble
>getting GeoMoose 2 to run over FGS on Ubuntu linuix 10.
>The FGS software
>appears to be working fine (the GMAP demo works flawlessly).
>Unfortunately when I
>attempted to run GeoMoose, the green template from the
>demo shows up,
>however no layers or tools work.  Firebug reported issues
>while loading
>getmapbook.php
><br />
><b>Warning</b>:
>dl() [<a href='function.dl'>function.dl</a>]: Unable to load
>dynamic library
>'/opt/fgs/www/lib/php5/php_curl.so' -
>/opt/fgs/www/lib/php5/php_curl.so:
>cannot open shared object file: No such
>file or directory in
><b>/opt/fgs/apps/geomoose2/htdocs/php/config.php</b> on
>line
><b>41</b><br />
><br />
>I noticed that there
>is no file called /opt/fgs/www/lib/php/config.php,
>however the is a file
>called php_mapscript_5.4.2
>What would my next
>steps be to get GeoMoose up and running?
>Thanks
>Mark Volz
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100527/510a0517/attachment.html
More information about the Geomoose-users mailing list
