[Geomoose-users] Scalebar & Measure
Dan Little danlittle at yahoo.com
Thu May 27 12:12:18 EDT 2010
Is there ever a reason why geodetic would be avoided (besides the compute cost in doing the math).  Also, I'm vehemently against adding arbitrary parameters to the XML definition.
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: Dan Little <danlittle at yahoo.com>
> Cc: Len Kne <lkne at houstoneng.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
> Sent: Thu, May 27, 2010 11:11:14 AM
> Subject: Re: [Geomoose-users] Scalebar & Measure
> How about omething like:
<tool name="measure"
> title="Measure"      type="internal" action="measure"
>   geodesic="false"/>
<tool name="measurearea" title="Measure Area"
> type="internal" action="measurearea" geodesic="false"/>
Note the
> default would be true so the implementer would need to turn it off if they
> wanted distances on the mapping plane.
Hmm. Does this imply I could
> have both geodesic AND map measures at the same time by creating these tools as
> well:
<tool name="measure2"     title="Measure Ground Dist"
> type="internal" action="measure"     geodesic="true"/>
<tool
> name="measurearea2" title="Measure Ground Area" type="internal"
> action="measurearea" geodesic="true"/>
Brent
Dan Little
> wrote:
> Probably just make it the default setting inside of the
> tools.
>> From:
> Brent Fraser <
> href="mailto:bfraser at geoanalytic.com">bfraser at geoanalytic.com>
> To: Len Kne <
> href="mailto:lkne at houstoneng.com">lkne at houstoneng.com>
>> Cc:
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net"
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net>
> Sent: Thu, May 27, 2010 10:02:01 AM
> Scalebar & Measure
>> Good.
>   Should we just hard-code it within Geomoose (as below), or
> provide a
> configuration parameter in the mapbook?
> Brent
> Len
>> Kne wrote:
>> Very nice!
> Worked great and is much simpler than the way I was doing the calculation.
>> Len
>> -----Original
> Message-----
>> From: Brent Fraser [mailto:
> ymailto="mailto:
> href="mailto:bfraser at geoanalytic.com">bfraser at geoanalytic.com"
> href="mailto:
> href="mailto:bfraser at geoanalytic.com">bfraser at geoanalytic.com">
> ymailto="mailto:bfraser at geoanalytic.com"
> href="mailto:bfraser at geoanalytic.com">bfraser at geoanalytic.com]
> Sent: Wednesday, May 26, 2010 1:53 PM
>> To: Len Kne
>> Cc:
>> ymailto="mailto:
> ymailto="mailto:geomoose-users at lists.sourceforge.net"
> href="mailto:
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net">
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net'
>> Len(and others interested in measuring),
>>    Here's my solution to the measure problem:
>> In main.js somewhere around line 138 add the two lines below marked
> with a "//BWF":
> Tools['measure'] = new
> OpenLayers.Control.GeoMooseMeasure(OpenLayers.Handler.MeasurePath,
> measureToolOptions);
>>     Tools['measure'].geodesic =
> true;  //BWF
>>     Tools['measurearea'] =
> new
> OpenLayers.Control.GeoMooseMeasure(OpenLayers.Handler.MeasurePolygon,
> Tools['measurearea'].geodesic = true;  //BWF
>> Thoughts?
>> Brent
>> Brent Fraser wrote:
>>> Paul, Len,
>>>    Our scale
>> problem is a (mostly) map
> projection issue.  All map projections
>>> introduce
> distortions in trying to represent a round(ish) Earth on
>> a flat
> plane.
>>>   Mercator is no different: it is like wrapping
>> an up-right cylinder around the
>>> Earth, projecting
> light from the
>> center onto the cylinder
> (http://en.wikipedia.org/wiki/Mercator_projection).  As you can imagine the
>>> distortions get "worse" the further from the equator.
> The
>> distortions can be
>>> modeled as a Point Scale
> Factor.  At the
>> equator the Point Scale Factor is 1.0,
>>> at latitude 60 degrees North
>> (or South), the scale
> factor is 0.5!
>>>    So
>> what's the
> solution?  Here's mine:
>>>    1.
> Enhance Proj4 (and Proj4js) to return the Point Scale factor (given the
>>> projection and a location)
>>>    2.
> Enhance
>> MapServer and Openlayers to use the Point Scale Factor in
> calculating distances and scale.
>>> I'm trying to drum up
>> interest, but so no takers....
> http://osgeo-org.1803224.n2.nabble.com/Point-Scale-factor-service-td4938743.html
> http://osgeo-org.1803224.n2.nabble.com/Re-3265-Scale-dependent-layer-switching-error-with-Mercator-td4966902.html
>> Best Regards,
>>> Brent Fraser
>>> Len Kne
>> wrote:
>>>> The scale bar
> issue with the web Mercator projection is a
>> limitation of
>>>> OpenLayers, the application GeoMOOSE 2.x uses to
>> render the map frame.
>>>>   There has been
> discussion on the
>> OpenLayers site about providing a
>>>> patch (this link offers a
>> patch
> http://trac.openlayers.org/ticket/1890 )
>>>> in the next
>> version 2.9.  I'm sure GM will upgrade to OL 2.9, but not sure
> there is any schedule in place to do this.
>>>> The
>> cursor issue is also kind of fun because
> it seems each browser handles the custom icons differently.  Here's the
> attribute in the
>>>> mapbook which defines the query for the
> Identify
>> service:
>> cursor="url('cursors/identify2.cur') 9
> 9,url('cursors/identify2.cur'),auto"
>>>>  This makes three
> attempts to draw the cursor,
>> the first offsets the
>>>> mouse click 9 pixels from the top and the
> left.  Firefox can use this
>>>> value and seems to line
> the
>> mouse click up pretty good with the
> crosshair.  However,
>> IE cannot handle the offset adjustment,
> so it reads
>>>> the second
>> cursor
> definition.  There are tools like AT File Mole which
> can be used to edit the hotspot of a cursor.  Attached is
>> the
> latest
>>>> version I have been using for Identify service,
>> again this seems to line
>>>> the crosshair up
> pretty well with the
>> mouse click.  If you are using
>>>> Safari or Chrome, these
>> setting don't seem to
> work at all and I would
>>>> recommend not
>> using
> customer cursors with those browsers.
>> Len
>> *From:* Wirth, Paul [mailto:
> href="mailto:
> href="mailto:Paul.Wirth at kniferiver.com">Paul.Wirth at kniferiver.com">
> ymailto="mailto:Paul.Wirth at kniferiver.com"
> href="mailto:Paul.Wirth at kniferiver.com">Paul.Wirth at kniferiver.com]
> *Sent:* Saturday, May 01, 2010 9:03 PM
>>>> *To:* '
> ymailto="mailto:
> href="mailto:
> *Subject:* [Geomoose-users] Scalebar & Measure
>> Two questions:
> 1.       I have a web Mercator
>> application, and I
> noticed that the
>>>> scalebar does not display
>> the
> correct distance.  For instance, when the
>>>> scalebar
>> shows a distance of 20 miles, it measures only 13.8 miles.  I
>>>> know the measure tools are working correctly, so I assume
> this
>> is a
>>>> scalebar issue.  Any thoughts
> on how to fix
>> this?
>>>> 2.       I
> think this
>> question was asked before, but I can't seem to
>>>> find it on the
>> e-mail list.  With the
> measure tools, the cursor does not start measuring at the "crosshairs" when the
> user clicks, but rather in
>>>> the NW quadrant of the
> crosshairs.  Is there a way to
>> change it so the
>>>> measure start point will be on the
> crosshairs?
> Geomoose-users
>> mailing list
>> ymailto="mailto:
> ymailto="mailto:Geomoose-users at lists.sourceforge.net"
> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lists.sourceforge.net"
> href="mailto:
> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lists.sourceforge.net">
> target=_blank
> href="https://lists.sourceforge.net/lists/listinfo/geomoose-users" target=_blank
>>> Geomoose-users
>> mailing list
>> ymailto="mailto:
> href="mailto:
> target=_blank
> Geomoose-users
>> mailing list
>> href="mailto:
>> href="
More information about the Geomoose-users mailing list
