[Geomoose-users] Feature report
    Brent Fraser
    bfraser at geoanalytic.com
    Thu Nov 25 09:45:31 EST 2010
Len,
   No worries; it gave me an opportunity to look into the
feature_reporting service...
Best Regards,
Brent Fraser
On 11/24/2010 4:24 PM, Len Kne wrote:
> Hi Brent
> Yes, I agree with your findings.  And feel bad that you spent time
> looking as I now see Jacob and I exchanged a couple emails that were
> not going to the list -- sorry.  Here are the missing emails for the
> record.
> Len
> I looked at the feature report service and I have to admit that I'm
> not sure it was ever working.  Specifically, I don't see where the
> script makes use of the "layers" parameter, explaining why the image
> does not show.
> I have been using a modified version of the print service for feature
> reports for some time.  It requires some tweaking of the Mapbook and
> MAP files, but it does work.  I will try to write up a wiki page for
> the changes within the next week.
> Len
> *From:*Jacob Rodel [mailto:jacob.rodel at co.todd.mn.us]
> *Sent:* Wednesday, November 24, 2010 10:12 AM
> *To:* Len Kne
> *Subject:* RE: Feature report
> Thanks Len!  I had a path issue.  The photos print now.  Although they
> still don't come through in the feature report.  Do I have everything
> right in the mapbook?  I'm not sure that is correct.
> *Jacob Rodel*
> GIS Technician
> Todd County GIS & Land Services Dept.
> 347 Central Ave. Suite 1
> Long Prairie, MN 56347
> (320) 732-4248
> *From:*Len Kne [mailto:lkne at houstoneng.com]
> *Sent:* Wednesday, November 24, 2010 9:34 AM
> *To:* Jacob Rodel
> In php/print_util.php, around line 173 is:
> #print $url;
> #print '<br/>';
> Uncomment those lines and try to print (easiest if you have just the
> photos turned on).  This should spit out the URL used to draw the
> photos.  Try running that URL in a separate browser tab and hopefully
> it will give a helpful error message.
> Len
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Wednesday, November 24, 2010 4:48 PM
> *To:* Len Kne
> *Cc:* 'Jacob Rodel'; geomoose-users at lists.sourceforge.net
> *Subject:* Re: [Geomoose-users] Feature report
> Len,
>   After reviewing feature_report.php, I don't think it renders any
> layers other than the layer being queried (e.g. the parcel layer).
> Can you confirm that?
> Jacob,
> As for the print service it could be that other layers are obscuring
> the imagery.  Can you print only the imagery?
> Best Regards,
> Brent Fraser
> On 11/24/2010 8:20 AM, Len Kne wrote:
> The only thing that I typically have in a MAP file with a tiled layer
> is the SHAPEPATH object.  Looks like the images are in the same
> location as your MAP file, so I don't know that this is necessary.
> Do other MapServer layers print?  For example the county boundaries
> that came with the demo.
> Len
> *Sent:* Wednesday, November 24, 2010 8:49 AM
> *To:* Len Kne; geomoose-users at lists.sourceforge.net
> <mailto:geomoose-users at lists.sourceforge.net>
> Still can't get my photo in the feature report or print service.  Any
> Ideas on what I am overlooking?
> *MAPBOOK:*
> <service name="feature_report" display="false">
> <step type="input">
> <url>php/feature_report.php</url>
> <input type="hidden" name="layers" value="photo/photo"/>
> <input type="hidden" name="src"/>
> <input type="hidden" name="TPPRCL"/>
> </step>
> </service>
> *MAPFILE:*
> MAP
>       NAME 'photo'
>       SIZE 800 650
>       STATUS ON
>       EXTENT 333610.042182818 5070249.37869356 373071.208536793
> 5137292.54244199
>       UNITS METERS
>       MAXSIZE 10000
>       TRANSPARENT true
>       IMAGETYPE jpeg
>       OUTPUTFORMAT
>             NAME jpeg
>             DRIVER "GD/JPEG"
>             MIMETYPE "image/jpeg"
>             IMAGEMODE RGB
>             EXTENSION "jpg"
>       END
>       PROJECTION
>             'init=epsg:26915'
>       END
>       LEGEND
>             STATUS ON
>             LABEL
>             TYPE TRUETYPE
>             FONT vera_sans
>             SIZE 8
>             COLOR 0 0 0
>             END
>       END
>   LAYER
>       NAME 'photo'
>       TILEINDEX 'photo.shp'
>       TILEITEM 'location'
>       STATUS ON
>       TYPE RASTER
>   End #layer  2008 Pictometry photos
> END ## end Map
> *SETTINGS.INI*
> [paths]
> root=/ms4w/apps/toddcounty/maps/
> temp=/ms4w/tmp/ms_tmp/
> mapserver_url=/cgi-bin/mapserv.exe
> server_name=localhost:80
> ; MS4W settings
> ; root=/ms4w/apps/toddcounty/maps/
> ; temp=/ms4w/tmp/ms_tmp/
> Jacob Rodel
> GIS Technician
> (320) 732-4248
> Increase Visibility of Your 3D Game App&  Earn a Chance To Win $500!
> Tap into the largest installed PC base&  get more eyes on your game by
> optimizing for Intel(R) Graphics Technology. Get started today with the
> Intel(R) Software Partner Program. Five $500 cash prizes are up for grabs.
> http://p.sf.net/sfu/intelisp-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net  <mailto:Geomoose-users at lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101125/b456bd61/attachment.html
More information about the Geomoose-users
