[Geomoose-users] identify service
Len Kne lkne at houstoneng.com
Wed Oct 6 17:52:50 EDT 2010
A couple things to check:
1.       Make sure the projection is set to 900913 in conf/settings.ini
2.       Were you getting XY returned with the Identify before making the changes?
3.       Take a look at the PARAMS and RESPONSE tab in FireBug  when running the Identify service.
4.       If the Identify is not returning the template information for individual layers, make sure the first line of the template file is <!-MapServer Template -->
Len
From: Sean Ziniker [mailto:Sean.Ziniker at co.jefferson.or.us]
Sent: Wednesday, October 06, 2010 4:46 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] identify service
Yes I did.  I tried both ways and same results.  The other thing I noticed is that I get no identify results; there is just a blank space.
Sean Ziniker
GIS Analyst
Jefferson County, Oregon
66 S.E. "D" Street, Suite B
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
Sent: Wednesday, October 06, 2010 2:42 PM
To: Sean Ziniker; geomoose-users at lists.sourceforge.net
Subject: RE: identify service
Looks right, did you see Steve Dougill's post to comment out:
#$map->queryByPoint($point, MS_MULTIPLE, -1);
Len
Sent: Wednesday, October 06, 2010 2:58 PM
Sorry, I forgot I reprojected my data into proj:900913 earlier do to a different conflict,  so the projection should be correct but I am still displaying x:-0, y:0
Sean Ziniker
GIS Analyst
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
Sent: Wednesday, October 06, 2010 12:42 PM
Sorry all, I first stated that $projInObj had to be in the map projection, but it should be the projection the data is in.  Sean, try the proj4 string for Oregon SP and it should work.
Len
Sent: Wednesday, October 06, 2010 2:25 PM
Len,
When I try the code change for latlong I get x:-0, y:0.  I am using 900913 projection and my shapefiles are in an Oregon State Plane.  If I change the projection portion of the code to my state plane projection I get values but they are incorrect.
Here is my code change:
if($queryShape->type == MS_SHAPE_POINT) {
                                    $point = $queryShape->line(0)->point(0);
                                    $clonePoint = $point;
                                    $projOutObj = ms_newprojectionobj("proj=latlong");
                                    $projInObj = ms_newprojectionobj("+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs");
                                    $clonePoint->project($projInObj, $projOutObj);
                                    $substArray['mapx'] = round($clonePoint->x,4);
                                    $substArray['mapy'] = round($clonePoint->y,4);
                        }else {
                                    $map->queryByShape($queryShape);
Do you have any idea what I am doing wrong?
Thanks
Sean Ziniker
GIS Analyst
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101006/8fcd9fef/attachment.html
More information about the Geomoose-users mailing list
