[Geomoose-users] Feature Editor Problem
Gregory Roberts | Wendler groberts at wendlergs.com
Wed Apr 6 10:56:58 EDT 2011
This doesn't seem to work. I get the error message: unterminated string
literal when editing any feature with or without an apostrophe.
  _____
Sent: Wednesday, April 06, 2011 8:16 AM
To: Dan Little; groberts at wendlergs.com; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Feature Editor Problem
Ugh... I'm writing this message again because the new Yahoo mail is
terrible.
The problem is not with the database.  That is actually working perfectly
and properly using variable binding.
The problem is with the identify template.  Specifically this line:
 <a href="javascript:GeoMOOSE.startService('modify_polygon',
{'feature:polygon_id' : '[polygon_id]','feature:wkb_geometry' :
'[wkt_geometry]', 'feature:title' : '[title]', 'feature:owner' :
'[owner]'})">Edit</a>
This modification should make things editable, though your users may be
unhappy with the "%27" displayed when they are editing the feature's title:
'[wkt_geometry]', 'feature:title' : '[title escape="url"]', 'feature:owner'
: '[owner escape="url"]'})">Edit</a>
Vector handling needs some major improvement.
  _____
To: "groberts at wendlergs.com" <groberts at wendlergs.com>;
"geomoose-users at lists.sourceforge.net"
<geomoose-users at lists.sourceforge.net>
Sent: Tuesday, April 5, 2011 11:26 PM
I would imagine that it's because variable binding is not happening for that
request.
Worst case scenario: I can probably send you a patch that escapes single
quotes (apostrophes)
Best case scenario: I fix it for real using PDO in 2.4.
  _____
From: Gregory Roberts | Wendler <groberts at wendlergs.com>
To: geomoose-users at lists.sourceforge.net
Sent: Tuesday, April 5, 2011 4:55 PM
Hello,
We have had an ongoing problem with the feature editor tool that occurs when
a user creates or edits a feature and inputs an apostrophe into a field.
Once the feature has been saved with an apostrophe the feature can no longer
be edited which results in us having to delete the apostrophe through the
back-end in postgres. We have already informed our users of this problem but
still have this occur a few times a week.
Does anyone else have any experience with this or any ideas as to how to go
about fixing it? Thanks very much.
Gregory
Xperia(TM) PLAY
It's a major breakthrough. An authentic gaming
smartphone on the nation's most reliable network.
And it wants your games.
http://p.sf.net/sfu/verizon-sfdev
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
Xperia(TM) PLAY
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110406/5a51e976/attachment.html
More information about the Geomoose-users mailing list
