[Geomoose-users] Feature Editor Problem
    Dan Little
    danlittle at yahoo.com
    Wed Apr  6 09:16:12 EDT 2011
Ugh... I'm writing this message again because the new Yahoo mail is terrible.
The problem is not with the database.  That is actually working perfectly and properly using variable binding.
The problem is with the identify template.  Specifically this line:
 <a href="javascript:GeoMOOSE.startService('modify_polygon', {'feature:polygon_id' : '[polygon_id]','feature:wkb_geometry' : '[wkt_geometry]', 'feature:title' : '[title]', 'feature:owner' : '[owner]'})">Edit</a>
This modification should make things editable, though your users may be unhappy with the "%27" displayed when they are editing the feature's title:
 <a href="javascript:GeoMOOSE.startService('modify_polygon', {'feature:polygon_id' : '[polygon_id]','feature:wkb_geometry' : '[wkt_geometry]', 'feature:title' : '[title escape="url"]', 'feature:owner' : '[owner escape="url"]'})">Edit</a>
Vector handling needs some major improvement.
>________________________________
>From: Dan Little <danlittle at yahoo.com>
>To: "groberts at wendlergs.com" <groberts at wendlergs.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Tuesday, April 5, 2011 11:26 PM
>Subject: Re: [Geomoose-users] Feature Editor Problem
>I would imagine that it's because variable binding is not happening for that request.
>Worst case scenario: I can probably send you a patch that escapes single quotes (apostrophes)
>Best case scenario: I fix it for real using PDO in 2.4.
>>From: Gregory Roberts | Wendler <groberts at wendlergs.com>
>>To: geomoose-users at lists.sourceforge.net
>>Sent: Tuesday, April 5, 2011 4:55 PM
>>Hello,
>>We have had an ongoing problem with the feature editor tool that occurs
when a user creates or edits a feature and inputs an apostrophe into a field.
Once the feature has been saved with an apostrophe the feature can no longer be
edited which results in us having to delete the apostrophe through the back-end
in postgres. We have already informed our users of this problem but still have
this occur a few times a week.
>>Does anyone else have any experience with this or any ideas as to how
to go about fixing it? Thanks very much.
>>Gregory
>>Xperia(TM) PLAY
>>It's a major breakthrough. An authentic gaming
>>smartphone on the nation's most reliable network.
>>And it wants your games.
>>http://p.sf.net/sfu/verizon-sfdev
>>_______________________________________________
>>Geomoose-users mailing list
>>Geomoose-users at lists.sourceforge.net
>>https://lists.sourceforge.net/lists/listinfo/geomoose-users
>Xperia(TM) PLAY
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110406/d10d1ded/attachment.html
More information about the Geomoose-users
