[Geomoose-users] GM 2.4 RC1, Mapserver 6.0 beta 5
Brent Fraser bfraser at geoanalytic.com
Fri Apr 8 16:01:52 EDT 2011
Yeah I thought it was a hack at the time..
Best Regards,
Brent Fraser
On 4/8/2011 2:00 PM, Dan Little wrote:
> That solution is sorta wrong...
> Something like..
> var olDiv = Map.div; // might now be ".element" or something similar
>     *From:* Brent Fraser <bfraser at geoanalytic.com>
>     *To:* John Callahan <john.callahan at udel.edu>
>     *Cc:* GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>     *Sent:* Friday, April 8, 2011 2:57 PM
>     *Subject:* Re: [Geomoose-users] GM 2.4 RC1, Mapserver 6.0 beta 5
>     John,
>     I ran into the olDiv problem in Dec
>     (http://sourceforge.net/mailarchive/message.php?msg_id=26773197):
>     > And while 2.9 doesn't work with GeoMoose trunk, 2.9.1 seems to
>     > work better with the exception of the cursor handling at line
>     850 in > main.js:
>     > // Add cursors > var olDiv = >
>     document.getElementById('mapContainer_OpenLayers_ViewPort');
>     > where olDiv gets set to null.
>     > Replacing the line with
>     > var olDiv =
>     document.getElementById('OpenLayers.Map_4_OpenLayers_ViewPort');
>     > makes it work.
>     Best Regards,
>     Brent Fraser
>     On 4/8/2011 12:34 PM, John Callahan wrote:
>>     I just downloaded the latest versions of GeoMoose 2.4 RC1 for
>>     MS4W and MS4W 3.0.2.   I also updated MS4W to use Mapserver 6.0
>>     beta5.   A few quick notes/questions I ran into:
>>     The GM demo showed a pink screen when first accessed.  To make
>>     the demo work, I had to do two things, thought the legends are
>>     off.  In geomoose_globals.map, change the OUTPUTFORMAT of jpeg to
>>     'AGG/JPG', as GD/JPEG did not seem to be working (error:
>>     loadOutputFormat(): General error message. OUTPUTFORMAT clause
>>     references driver GD/JPEG, but this driver isn't configured.)  I
>>     couldn't tell if GD is being removed from MS6 or not.
>>     I also had to comment out the GAP and STYLE elements in
>>     symbol.sym.  Apparently, STYLE was renamed to PATTERN and moved
>>     up to the STYLE section.  GAP was also moved to the STYLE
>>     section.  (http://mapserver.org/trunk/mapfile/symbol.html)
>>     GM 2.4 ships with OpenLayers 2.8 but MS4W ships with OpenLayers
>>     2.10.  (I think OSGeo4W ships with OL 2.9 or 2.10.)   I pointed
>>     the GM demo to OL2.10 and  received this error: "olDiv is null".
>>     Not that they have to match but could/should GM ship with OL2.10?
>>     As far as GeoMoose goes, and assuming all of my data are local,
>>     does it matter if my own data layers are Mapserver layers or WMS
>>     layers created by Mapserver?  Some of my data will be served as
>>     individual WMS layers anyway.  This is proabbly more of a
>>     Mapserver/mapscript question though.
>>     - John
>>     John Callahan, Research Scientist
>>     Delaware Geological Survey, University of Delaware
>>     URL: http://www.dgs.udel.edu
>>     Xperia(TM) PLAY
>>     It's a major breakthrough. An authentic gaming
>>     smartphone on the nation's most reliable network.
>>     And it wants your games.
>>     http://p.sf.net/sfu/verizon-sfdev
>>     _______________________________________________
>>     Geomoose-users mailing list
>>     Geomoose-users at lists.sourceforge.net  <mailto:Geomoose-users at lists.sourceforge.net>
>>     https://lists.sourceforge.net/lists/listinfo/geomoose-users
>     Xperia(TM) PLAY
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110408/cdd10590/attachment.html
More information about the Geomoose-users mailing list
