[Geomoose-users] GM 2.4 RC1, Mapserver 6.0 beta 5
John Callahan john.callahan at udel.edu
Fri Apr 8 16:37:37 EDT 2011
Thanks for the quick responses.  I'll stick with WMS for my data layers and
OL 2.8, until I understand things better or need something different.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
On Fri, Apr 8, 2011 at 4:01 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Yeah I thought it was a hack at the time..
> Best Regards,
> Brent Fraser
> On 4/8/2011 2:00 PM, Dan Little wrote:
>  That solution is sorta wrong...
>  Something like..
>  var olDiv = Map.div; // might now be ".element" or something similar
> *From:* Brent Fraser <bfraser at geoanalytic.com> <bfraser at geoanalytic.com>
> *To:* John Callahan <john.callahan at udel.edu> <john.callahan at udel.edu>
> *Cc:* GeoMOOSE Users List <geomoose-users at lists.sourceforge.net><geomoose-users at lists.sourceforge.net>
> *Sent:* Friday, April 8, 2011 2:57 PM
> *Subject:* Re: [Geomoose-users] GM 2.4 RC1, Mapserver 6.0 beta 5
>  John,
> I ran into the olDiv problem in Dec (
> http://sourceforge.net/mailarchive/message.php?msg_id=26773197):
> > And while 2.9 doesn't work with GeoMoose trunk, 2.9.1 seems to
> > work better with the exception of the cursor handling at line 850 in >
> main.js:
> > // Add cursors > var olDiv = >
> document.getElementById('mapContainer_OpenLayers_ViewPort');
> > where olDiv gets set to null.
> > Replacing the line with
> > var olDiv =
> document.getElementById('OpenLayers.Map_4_OpenLayers_ViewPort');
> > makes it work.
> Best Regards,
> Brent Fraser
> On 4/8/2011 12:34 PM, John Callahan wrote:
> I just downloaded the latest versions of GeoMoose 2.4 RC1 for MS4W and MS4W
> 3.0.2.   I also updated MS4W to use Mapserver 6.0 beta5.   A few quick
> notes/questions I ran into:
> The GM demo showed a pink screen when first accessed.  To make the demo
> work, I had to do two things, thought the legends are off.  In
> geomoose_globals.map, change the OUTPUTFORMAT of jpeg to 'AGG/JPG', as
> GD/JPEG did not seem to be working (error: loadOutputFormat(): General error
> message. OUTPUTFORMAT clause references driver GD/JPEG, but this driver
> isn't configured.)  I couldn't tell if GD is being removed from MS6 or not.
> I also had to comment out the GAP and STYLE elements in symbol.sym.
> Apparently, STYLE was renamed to PATTERN and moved up to the STYLE section.
> GAP was also moved to the STYLE section.  (
> http://mapserver.org/trunk/mapfile/symbol.html)
> GM 2.4 ships with OpenLayers 2.8 but MS4W ships with OpenLayers 2.10.  (I
> think OSGeo4W ships with OL 2.9 or 2.10.)   I pointed the GM demo to OL2.10
> and  received this error: "olDiv is null".  Not that they have to match but
> could/should GM ship with OL2.10?
> As far as GeoMoose goes, and assuming all of my data are local, does it
> matter if my own data layers are Mapserver layers or WMS layers created by
> Mapserver?  Some of my data will be served as individual WMS layers anyway.
> This is proabbly more of a Mapserver/mapscript question though.
> - John
> Xperia(TM) PLAY
> It's a major breakthrough. An authentic gaming
> smartphone on the nation's most reliable network.
> And it wants your games.http://p.sf.net/sfu/verizon-sfdev
> Geomoose-users mailing listGeomoose-users at lists.sourceforge.nethttps://lists.sourceforge.net/lists/listinfo/geomoose-users
> Xperia(TM) PLAY
> Xperia(TM) PLAY
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110408/5e50533a/attachment.html
More information about the Geomoose-users mailing list
