[Geomoose-users] feature editing - able to add polygons, not able
to delete or edit.
Atif Butt
matifbutt at gmail.com
Fri Dec 2 14:04:34 EST 2011
Hi Dora
The URL dose work, but its not working inside Internet Explorer (I dont
know why). But if you can try inside firefox, or any other borwser then it
should be fine.
Try again Please: http://99.243.192.221/geomoose2/geomoose.html
Secondly, as Dan Little pointed me the same error. so I changed my map file
with this code
'wkb_geometry from (select polygon_id, title, owner, astext(wkb_geometry)
as wkt_geometry, wkb_geometry from test_polygons) as mytable using unique
polygon_id using srid=-1'
Regards
Atif
On Fri, Dec 2, 2011 at 9:37 AM, Dara Olson <dolson at glifwc.org> wrote:
> Your URL won't work - I don't think you are online and just running
> through your local network.
> What projection is your data in (SRID)? What projection is your
> application in (SRID)? Try below and insert your SRID where the XXXXX are,
> but make sure that your application and data are in the same SRID.
> DATA "'wkb_geometry FROM (SELECT polygon_id, title, owner,
> astext(wkb_geometry) as wkt_geometry FROM
> from test_polygons) as mytable using unique polygon_id using srid=XXXXX"
> Dara
> ----- Original Message -----
> *From:* Atif Butt <matifbutt at gmail.com>
> *To:* Dan Little <danlittle at yahoo.com>
> *Cc:* Brent Fraser <bfraser at geoanalytic.com> ;
> geomoose-users at lists.osgeo.org ; dolson at glifwc.org
> *Sent:* Friday, December 02, 2011 2:33 AM
> *Subject:* Re: [Geomoose-users] feature editing - able to add polygons,
> not able to delete or edit.
> FYI
> On Fri, Dec 2, 2011 at 3:32 AM, Atif Butt <matifbutt at gmail.com> wrote:
>> I have change this in the map file, but no success.
>> Could you please check the URL of my mapserver running geomoose2.
>> In this way you might understand whats wrong in this feature editing.
>> Regards
>> Atif
>> On Tue, Nov 29, 2011 at 3:54 PM, Dan Little <danlittle at yahoo.com> wrote:
>>> Ah, this is actually kinda an easy one. There is a projections
>>> conflict for MapServer.
>>> I'd try editing your mapfile and changing:
>>> DATA 'wkb_geometry from (select polygon_id, title, owner,
>>> astext(wkb_geometry) as wkt_geometry, wkb_geometry from test_polygons) as
>>> mytable using unique polygon_id'
>>> To:
>>> mytable using unique polygon_id using srid=-1'
>>> I might be a little off on the syntax.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111202/5119639d/attachment.html
More information about the Geomoose-users
