[Geomoose-users] feature editing - able to add polygons, not able
to delete or edit.
Atif Butt
matifbutt at gmail.com
Fri Dec 2 14:29:18 EST 2011
Yes Dora, Finally, feature editor is started working. Now I can start other
feature editors thing like delete, modify, etc.
But I wasnt aware of this error, why this geomoose not opening inside the
IE 7 and IE8, same green background nothing else is showing up.
Kindly check http://99.243.192.221/geomoose2/geomoose.html
Regards
On Fri, Dec 2, 2011 at 2:04 PM, Atif Butt <matifbutt at gmail.com> wrote:
> Hi Dora
> The URL dose work, but its not working inside Internet Explorer (I dont
> know why). But if you can try inside firefox, or any other borwser then it
> should be fine.
> Try again Please: http://99.243.192.221/geomoose2/geomoose.html
> Secondly, as Dan Little pointed me the same error. so I changed my map
> file with this code
> 'wkb_geometry from (select polygon_id, title, owner, astext(wkb_geometry)
> as wkt_geometry, wkb_geometry from test_polygons) as mytable using unique
> polygon_id using srid=-1'
> Regards
> Atif
> On Fri, Dec 2, 2011 at 9:37 AM, Dara Olson <dolson at glifwc.org> wrote:
>> Your URL won't work - I don't think you are online and just running
>> through your local network.
>> What projection is your data in (SRID)? What projection is your
>> application in (SRID)? Try below and insert your SRID where the XXXXX are,
>> but make sure that your application and data are in the same SRID.
>> DATA "'wkb_geometry FROM (SELECT polygon_id, title, owner,
>> astext(wkb_geometry) as wkt_geometry FROM
>> from test_polygons) as mytable using unique polygon_id using srid=XXXXX"
>> Dara
>> ----- Original Message -----
>> *From:* Atif Butt <matifbutt at gmail.com>
>> *To:* Dan Little <danlittle at yahoo.com>
>> *Cc:* Brent Fraser <bfraser at geoanalytic.com> ;
>> geomoose-users at lists.osgeo.org ; dolson at glifwc.org
>> *Sent:* Friday, December 02, 2011 2:33 AM
>> *Subject:* Re: [Geomoose-users] feature editing - able to add polygons,
>> not able to delete or edit.
>> FYI
>> On Fri, Dec 2, 2011 at 3:32 AM, Atif Butt <matifbutt at gmail.com> wrote:
>>> I have change this in the map file, but no success.
>>> Could you please check the URL of my mapserver running geomoose2.
>>> In this way you might understand whats wrong in this feature editing.
>>> Regards
>>> Atif
>>> On Tue, Nov 29, 2011 at 3:54 PM, Dan Little <danlittle at yahoo.com> wrote:
>>>> Ah, this is actually kinda an easy one. There is a projections
>>>> conflict for MapServer.
>>>> I'd try editing your mapfile and changing:
>>>> DATA 'wkb_geometry from (select polygon_id, title, owner,
>>>> astext(wkb_geometry) as wkt_geometry, wkb_geometry from test_polygons) as
>>>> mytable using unique polygon_id'
>>>> To:
>>>> mytable using unique polygon_id using srid=-1'
>>>> I might be a little off on the syntax.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111202/9c8d5589/attachment.html
More information about the Geomoose-users
