[Geomoose-users] Re: Identify & popup issues
Efstathios Arapostathis e.arapostathis at gmail.com
Thu Dec 8 11:52:20 EST 2011
Application is accessible through this link:
*http://195.251.31.2/museum_geomoose2/*
best regards,
Stathis Arapostathis
On Thu, Dec 8, 2011 at 6:47 PM, Efstathios Arapostathis <
e.arapostathis at gmail.com> wrote:
> Hi,
> The following message appears:
> *MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE  SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE*
> On Wed, Dec 7, 2011 at 6:56 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>>  Using a command line (in the directory containing mapserver executed by
>> your webserver) what does the command "mapserv -v" show?
>> Best Regards,
>> Brent Fraser
>> On 12/7/2011 9:38 AM, Efstathios Arapostathis wrote:
>> It's already  uncommented..
>> Any ideas?
>> *Config.php:*
>> <?php
>> /*Copyright (c) 2009, Dan "Ducky" Little & GeoMOOSE.org
>> Permission is hereby granted, free of charge, to any person obtaining a
>> copy
>> of this software and associated documentation files (the "Software"), to
>> deal
>> in the Software without restriction, including without limitation the
>> rights
>> to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
>> copies of the Software, and to permit persons to whom the Software is
>> furnished to do so, subject to the following conditions:
>> The above copyright notice and this permission notice shall be included in
>> all copies or substantial portions of the Software.
>> THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
>> IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
>> FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
>> THE
>> AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
>> LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
>> FROM,
>> OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
>> THE SOFTWARE.*/
>> # This is meant to allow specific environmental includes for
>> # GeoMOOSE 2 PHP Services.  Substantive configuraiton options
>> # should be added to settings.ini
>> /* Check for the required libraries
>>  * g2/curl are used for printing. If you're not using printing
>>  * you can avoid using these modules.
>>  * mapscript and dbase are used for most operations using them
>>  * cannot be avoided
>> if(!extension_loaded('gd') && !extension_loaded('gd2')) {
>>     dl('php_gd2.'.PHP_SHLIB_SUFFIX);
>> if(!extension_loaded('curl')) {
>>     dl('php_curl.'.PHP_SHLIB_SUFFIX);
>> if(!extension_loaded('MapScript')) {
>>     dl('php_mapscript.'.PHP_SHLIB_SUFFIX);
>> if(!extension_loaded('dbase')) {
>>     dl('php_dbase.'.PHP_SHLIB_SUFFIX);
>> # Load the configration file
>> $CONFIGURATION = parse_ini_file('../../conf/settings.ini');
>> function getMapbook() {
>>     global $CONFIGURATION;
>>     $mapbook = new DOMDocument();
>>     $mapbook->load('../../conf/'.$CONFIGURATION['mapbook']);
>>     return $mapbook;
>> function getUsername() {
>>     session_start();
>>     return $_SESSION['username'];
>> # Select Functionality ONLY works for Mapserver Layers
>> function getMapfile($mb, $layerName) {
>>     $services = $mb->getElementsByTagName('map-source');
>>     $mapfiles = array();
>>     for($i = 0; $i < $services->length; $i++) {
>>         $service = $services->item($i);
>>         $root = $service->getAttribute('name');
>>         $layers = $service->getElementsByTagName('layer');
>>         for($l = 0; $l < $layers->length; $l++) {
>>             $layer = $layers->item($l);
>>             $path = $root.'/'.$layer->getAttribute('name');
>>             if($path == $layerName) {
>>                 return
>> $service->getElementsByTagName('file')->item(0)->nodeValue;
>>     return null;
>> # get a source based on it's name
>> function getMapSource($mb, $layerName) {
>>         if($services->item($i)->getAttribute('name') == $layerName) {
>>             return $services->item($i);
>>     return null;
>> On Mon, Dec 5, 2011 at 6:52 PM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>>> Since you are using PHP 5.2.4 I don't think that is an issue, but in
>>> later PHP versions, dl has been removed,
>>> http://us2.php.net/manual/en/function.dl.php
>>> Eli
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111208/b209eec5/attachment-0001.html
More information about the Geomoose-users mailing list
