[Geomoose-users] Re: Identify & popup issues
Brent Fraser
bfraser at geoanalytic.com
Thu Dec 8 12:25:01 EST 2011
The important part is that is has "SUPPORTS=GEOS", so that's good
(from Googling, this is the component that supplies the
ms_shapeObjFromWkt function to mapserver).
You've got a serious and uncommon mapserver configuration problem.
To figure out why the function is not available, I'd recommend making a
simple PHP script containing ms_shapeObjFromWkt and executing it from
command line. Or use PHP's get_extension_funcs('MapScript') function
to list the function names that are available in mapserver's MapScript:
<?php
if(!extension_loaded('MapScript')) {
dl('php_mapscript.'.PHP_SHLIB_SUFFIX);
echo implode('<br /> ', get_extension_funcs('MapScript') ), '<br />';
Best Regards,
Brent Fraser
On 12/8/2011 9:47 AM, Efstathios Arapostathis wrote:
> Hi,
> The following message appears:
> *MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE*
> On Wed, Dec 7, 2011 at 6:56 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
> Using a command line (in the directory containing mapserver
> executed by your webserver) what does the command "mapserv -v" show?
> Best Regards,
> Brent Fraser
> On 12/7/2011 9:38 AM, Efstathios Arapostathis wrote:
>> It's already uncommented..
>> Any ideas?
>> /*Config.php:*/
>> <?php
>> /*Copyright (c) 2009, Dan "Ducky" Little & GeoMOOSE.org
>> Permission is hereby granted, free of charge, to any person
>> obtaining a copy
>> of this software and associated documentation files (the
>> "Software"), to deal
>> in the Software without restriction, including without limitation
>> the rights
>> to use, copy, modify, merge, publish, distribute, sublicense,
>> and/or sell
>> copies of the Software, and to permit persons to whom the Software is
>> furnished to do so, subject to the following conditions:
>> The above copyright notice and this permission notice shall be
>> included in
>> all copies or substantial portions of the Software.
>> THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
>> EXPRESS OR
>> IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
>> MERCHANTABILITY,
>> FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT
>> SHALL THE
>> AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
>> OTHER
>> LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
>> ARISING FROM,
>> OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
>> DEALINGS IN
>> THE SOFTWARE.*/
>> # This is meant to allow specific environmental includes for
>> # GeoMOOSE 2 PHP Services. Substantive configuraiton options
>> # should be added to settings.ini
>> /* Check for the required libraries
>> * g2/curl are used for printing. If you're not using printing
>> * you can avoid using these modules.
>> * mapscript and dbase are used for most operations using them
>> * cannot be avoided
>> if(!extension_loaded('gd') && !extension_loaded('gd2')) {
>> dl('php_gd2.'.PHP_SHLIB_SUFFIX);
>> if(!extension_loaded('curl')) {
>> dl('php_curl.'.PHP_SHLIB_SUFFIX);
>> if(!extension_loaded('dbase')) {
>> dl('php_dbase.'.PHP_SHLIB_SUFFIX);
>> # Load the configration file
>> $CONFIGURATION = parse_ini_file('../../conf/settings.ini');
>> function getMapbook() {
>> global $CONFIGURATION;
>> $mapbook = new DOMDocument();
>> $mapbook->load('../../conf/'.$CONFIGURATION['mapbook']);
>> return $mapbook;
>> function getUsername() {
>> session_start();
>> return $_SESSION['username'];
>> # Select Functionality ONLY works for Mapserver Layers
>> function getMapfile($mb, $layerName) {
>> $services = $mb->getElementsByTagName('map-source');
>> $mapfiles = array();
>> for($i = 0; $i < $services->length; $i++) {
>> $service = $services->item($i);
>> $root = $service->getAttribute('name');
>> $layers = $service->getElementsByTagName('layer');
>> for($l = 0; $l < $layers->length; $l++) {
>> $layer = $layers->item($l);
>> $path = $root.'/'.$layer->getAttribute('name');
>> if($path == $layerName) {
>> return
>> $service->getElementsByTagName('file')->item(0)->nodeValue;
>> return null;
>> # get a source based on it's name
>> function getMapSource($mb, $layerName) {
>> if($services->item($i)->getAttribute('name') == $layerName) {
>> return $services->item($i);
>> return null;
>> On Mon, Dec 5, 2011 at 6:52 PM, Eli Adam <eadam at co.lincoln.or.us
>> <mailto:eadam at co.lincoln.or.us>> wrote:
>> Since you are using PHP 5.2.4 I don't think that is an issue,
>> but in
>> later PHP versions, dl has been removed,
>> http://us2.php.net/manual/en/function.dl.php
>> Eli
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111208/6a03ae9e/attachment.html
More information about the Geomoose-users
