[Geomoose-users] printing in geomoose
Brent Fraser
bfraser at geoanalytic.com
Thu Dec 15 12:35:56 EST 2011
GeoMoose Printing does not support printing data directly from tile
servers (Google, OpenstreetMap). There is a work-around by having
mapserver get the tiles and produce an image
(http://www.osgeo.org/pipermail/geomoose-users/2010-July/002435.html)
Best Regards,
Brent Fraser
On 12/12/2011 8:19 AM, tripin2 wrote:
> When I try to print just one layer it gives me the bounding box error
> mentioned before... When i try to print only baselayer, for example
> openstreet map tiles loaded from tah.openstreetmap.org, i get blank image.
> As I maybe failed to state clearly, I use geoserver instead of mapserver...
> But there should be no problem, i suppose.
> The error references coordinates like 1 607 164 is number in the correct
> range of values for my coordinate
> system, and I am trying to print area of Prague, Czech republic... It's
> correct.
> I don't know how you mean "to try tracing backwards from here to try and
> find it". Sorry, but I have no clue, where the problem is or where it could
> be. And if I had an idea, i don't know how to trace it and so on.. I'm
> really sorry. And also I would like to thank you for your help!
> View this message in context: http://geomoose-users.964460.n3.nabble.com/printing-in-geomoose-tp3572984p3579709.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
