[Geomoose-users] printing in geomoose
    tripin2
    melicherr at kolektory.cz
    Mon Dec 19 05:45:13 EST 2011
Hi there.
When i try to find mapserver version I get this:
$ /usr/lib/cgi-bin/mapserv -v
MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
and location of library php_mapscript.so is:
$ locate php_mapscript.so
/usr/lib/php5/20090626/php_mapscript.so
Eli Adam >> I've not been able to think of any great ideas on this.  Does
everything on the map display fine?  Does your GeoServer wms work as
expected in a desktop client (qgis, udig, ArcMap, etc)?  If you know of a
WMS in your geographic region that is is your coordinate system, you may
want to try with that to see if it prints. <<
I can connect to my geoserver through QGIS and uDig etc... And from what I
have tried until now, it seems it is working fine. I loaded shapefiles in
uDig and QGIS and they are on the right place, it work fast enough, it took
just a few tenths of a second to view them...
I tried to print wms data from our OFFICE FOR SURVEYING, MAPPING AND
CADASTRE and I got a blank image. I think this is the same problem as with
my tries to print an open street map base layer. But when I cascaded the
same wms to my geoserver app and tried to print it in geomoose I got the
same "zero area" error. So I think, there is some error in comunication
between geomoose and geoserver or between php print request and getting the
data from geoserver.
Thank you very much
View this message in context: http://geomoose-users.964460.n3.nabble.com/printing-in-geomoose-tp3572984p3598025.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
More information about the Geomoose-users
