[Geomoose-users] POLL: Geomoose 2.2 or 2.4 on the Live DVD, which is more stable?
Dan Little danlittle at yahoo.com
Wed Jun 15 13:44:32 EDT 2011
There is absolutely nothing in 2.2 that should work that doesn't in 2.4.  The code is not that different.  Fix your configuration.
>________________________________
>From: Bob Basques <Bob.Basques at ci.stpaul.mn.us>
>To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Wednesday, June 15, 2011 11:30 AM
>Subject: Re: [Geomoose-users] POLL:  Geomoose 2.2 or 2.4 on the Live DVD, which is more stable?
>Dan,
>That's the problem.  I had to build a case to include some local demos in the LIVE DVD installer ,but not everything seems to work in the 2.2 stuff, so to fix, it seems better to address the same capabilities in the 2.4 version instead of repairing the 2.2 demos.
>bobb
>>>> Dan Little <danlittle at yahoo.com> wrote:
>Ugh... Yeah, GM2.4 has a ton of fixes that are reasonably important.  Especially when you take it away from the demo configuration.
>>To: geomoose-users at lists.sourceforge.net
>>Sent: Wednesday, June 15, 2011 9:24 AM
>>Subject: [Geomoose-users] POLL: Geomoose 2.2 or 2.4 on the Live DVD, which is more stable?
>>All,
>>in your estimation (of those that have used GM2.4, would you think that 2.4 is more or as stable as GM2.2?
>>It has been suggested that using GM2.2 for the LiveDVD may be better than going with a newer version.
>>Any thoughts?
>>bobb
>>EditLive Enterprise is the world's most technically advanced content
>>authoring tool. Experience the power of Track Changes, Inline Image
>>Editing and ensure content is compliant with Accessibility Checking.
>>http://p.sf.net/sfu/ephox-dev2dev
>>_______________________________________________
>>Geomoose-users mailing list
>>Geomoose-users at lists.sourceforge.net
>>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110615/30390fe5/attachment.html
More information about the Geomoose-users mailing list
