[Geomoose-users] Making background color transparent
Eli Adam
EAdam at co.lincoln.or.us
Wed Mar 23 16:20:27 EDT 2011
Bob,
What is your output format? And specifically does it support transparency? There are some details in this message,
http://sourceforge.net/mailarchive/message.php?msg_id=26914717
Also for MapServer services, are you using <param name="TRANSPARENT" value="TRUE"/> same for requesting a format the supports transparency.
Eli
PS Searching the email archives is available here, http://sourceforge.net/search/?group_id=160935&type_of_search=mlists
>>> On 3/23/2011 at 12:58 PM, in message
<4EFF8BB964547748A07CA32961810C041AD68E56 at SOM-TEAQASMAIL1.som.w2k.state.me.us>,
"Bistrais, Bob" <Bob.Bistrais at maine.gov> wrote:
> Hi, I'm new to Geomoose and just learning my way around. I've been able
> to incorporate my own data into Geomoose. The problem is, when one
> layer draws over another, it has a white background which obscures the
> underlying layer. I tried using the MapServer Offsite keyword in that
> layer's map file, but that doesn't seem to do the trick. My test app
> has two layers, which are both MapServer services.
More information about the Geomoose-users
