[Geomoose-users] Making background color transparent
Bistrais, Bob
Bob.Bistrais at maine.gov
Wed Mar 23 16:35:01 EDT 2011
Perfect! Setting the Imagecolor and Transparent=true did the trick.
Thanks!
-----Original Message-----
Sent: Wednesday, March 23, 2011 4:20 PM
To: geomoose-users at lists.sourceforge.net; Bistrais, Bob
Subject: Re: [Geomoose-users] Making background color transparent
Bob,
What is your output format? And specifically does it support
transparency? There are some details in this message,
http://sourceforge.net/mailarchive/message.php?msg_id=26914717
Also for MapServer services, are you using <param name="TRANSPARENT"
value="TRUE"/> same for requesting a format the supports transparency.
Eli
PS Searching the email archives is available here,
http://sourceforge.net/search/?group_id=160935&type_of_search=mlists
>>> On 3/23/2011 at 12:58 PM, in message
<4EFF8BB964547748A07CA32961810C041AD68E56 at SOM-TEAQASMAIL1.som.w2k.state.
me.us>,
"Bistrais, Bob" <Bob.Bistrais at maine.gov> wrote:
> Hi, I'm new to Geomoose and just learning my way around. I've been
able
> to incorporate my own data into Geomoose. The problem is, when one
> layer draws over another, it has a white background which obscures the
> underlying layer. I tried using the MapServer Offsite keyword in that
> layer's map file, but that doesn't seem to do the trick. My test app
> has two layers, which are both MapServer services.
More information about the Geomoose-users
