[Geomoose-users] Controlling reference map
Bistrais, Bob Bob.Bistrais at maine.gov
Thu Mar 24 09:28:04 EDT 2011
OK, I'm having some success with these.  Thanks!
-----Original Message-----
Sent: Wednesday, March 23, 2011 5:56 PM
To: geomoose-users at lists.sourceforge.net; Bistrais, Bob
Subject: Re: [Geomoose-users] Controlling reference map
You can look into these parameters.
		<param name="reference_map.mimimum_ratio">1</param>
		<param
name="reference_map.maximum_ratio">1000000</param>
		<param name="reference_map.maximized">true</param>
HTH, Eli
>>> On 3/23/2011 at 1:27 PM, in message
<4EFF8BB964547748A07CA32961810C041AD68E79 at SOM-TEAQASMAIL1.som.w2k.state.
me.us>,
"Bistrais, Bob" <Bob.Bistrais at maine.gov> wrote:
> Hi Eli,
> Thanks!  That seems to help.  In particular, adding another "scales"
> value helped it out.  Is there any way to explicitly keep the
reference
> map at a fixed scale, or limit the maximum (most zoomed-in) scale?
> From: Eli Adam [mailto:EAdam at co.lincoln.or.us]
> Sent: Wednesday, March 23, 2011 4:12 PM
> Bob,
>      Did you try things suggested in this previous email?
> http://sourceforge.net/mailarchive/message.php?msg_id=26111291
> HTH, Eli
>>>> On 3/23/2011 at 1:02 PM, in message
<4EFF8BB964547748A07CA32961810C041AD68E59 at SOM-TEAQASMAIL1.som.w2k.state.
> me.us>,
>> Is there a way to control the extent of the reference map?  Even when
>> the main map is at a statewide extent, the reference map shows a
> smaller
>> area.  And this varies depending on how much you zoom in or at.  It
>> could be disorienting to a user.  What parameters control the extent
> of
>> the reference map, and can I edit these?
> Enable your software for Intel(R) Active Management Technology to meet
the
> growing manageability and security demands of your customers.
Businesses
> are taking advantage of Intel(R) vPro (TM) technology - will your
software
> be a part of the solution? Download the Intel(R) Manageability Checker
> today! http://p.sf.net/sfu/intel-dev2devmar
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
