[Geomoose-users] Using Identify with Postgis layer
Stephen Knox
stephenknox73 at gmail.com
Mon May 2 10:18:25 EDT 2011
Dan,
Thank you. That did the trick! Kicking myself! Thank you very much for you
prompt and gracious help!
Steve
On Mon, May 2, 2011 at 3:08 PM, Dan Little <danlittle at yahoo.com> wrote:
> I suspected you were using a dynamic view.
> Add "riding" and "number" to your select statement and you should see
> things start working. "number" is a reserved word so you might need to use
> PostgreSQL to create a view to account for that because you cannot escape "s
> in MapServer < 6.0.
> So you might need something like:
> create view my_voters_view as
> SELECT gid, the_geom, "number" as n_voters, riding as n_riding,
> vtotal::REAL / vregist::REAL AS percent FROM bc_voting_areas WHERE vregist >
> 0;
> That'll clean up your mapfile a little bit too (visually/readability).
> *From:* Stephen Knox <stephenknox73 at gmail.com>
> *To:* Dan Little <danlittle at yahoo.com>;
> geomoose-users at lists.sourceforge.net
> *Sent:* Monday, May 2, 2011 8:56 AM
> *Subject:* Re: [Geomoose-users] Using Identify with Postgis layer
> Sorry,
> Never query in haste! I was just using a generic field name, but the below
> covers everything. It's just data for playing around with really, from a
> tutorial.
> Here is the mapfile:
> MAP
> IMAGETYPE PNG
> EXTENT 0 0 2000000 2000000
> SIZE 1000 1000
> IMAGECOLOR 255 255 255
> PROJECTION
> "init=epsg:3005"
> END
> LAYER
> CONNECTIONTYPE postgis
> NAME "voting"
> CONNECTION "user=**** password=**** dbname=Unit5 host=localhost"
> DATA "the_geom from (SELECT gid, the_geom, vtotal::REAL / vregist::REAL AS
> percent FROM bc_voting_areas WHERE vregist > 0) as foo using srid=3005 using
> unique gid"
> STATUS ON
> TYPE POLYGON
> METADATA
> identify_record "identify_voting.html"
> END
> CLASS
> COLOR 200 0 0
> EXPRESSION ([percent] > 0.7)
> END
> CLASS
> COLOR 200 200 0
> EXPRESSION ([percent] < 0.7)
> END
> END
> END
> The identify_voting.html definition:
> <!-- MapServer Template -->
> <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Voting Districts</u></b></tr>
> <tr>
> <td align="right"><b>DistName:</b></td>
> <td>[riding]</td>
> </tr>
> <tr>
> <td align="right"><b>Number of Voters:</b></td>
> <td>[number]</td>
> </tr>
> <tr>
> <td> </td>
> <td> </td>
> </tr>
> and the postgis table definition:
> CREATE TABLE bc_voting_areas
> gid serial NOT NULL,
> code character varying(3),
> id character varying(8),
> riding character varying(29),
> region character varying(29),
> "number" character varying(4),
> ndp numeric(11,0),
> liberal numeric(11,0),
> green numeric(11,0),
> unity numeric(11,0),
> vtotal numeric(11,0),
> vreject numeric(11,0),
> vregist numeric(11,0),
> the_geom geometry,
> CONSTRAINT bc_voting_areas_pkey PRIMARY KEY (gid),
> CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'MULTIPOLYGON'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 3005)
> WITH (
> OIDS=FALSE
> ALTER TABLE bc_voting_areas OWNER TO postgres;
> CREATE INDEX bc_voting_areas_geom_idx
> ON bc_voting_areas
> USING gist
> (the_geom);
> CREATE INDEX bc_voting_areas_the_geom_gist
> ON bc_voting_areas
> USING gist
> (the_geom);
> On Mon, May 2, 2011 at 1:31 PM, Dan Little <danlittle at yahoo.com> wrote:
> Is "feature_name" a field in your table?
> Any chance we can see the definition of the table, the mapfile, and
> template that you are using?
> *To:* geomoose-users at lists.sourceforge.net
> *Sent:* Monday, May 2, 2011 5:57 AM
> Hi list,
> I came across GeoMoose through a university project to create a mapping
> server. I've managed to get it working fairly well with Mapserver and
> PostGIS data (and looking good, thanks!), but I was just wondering whether
> anyone has used "Identify" with PostGIS layers. I have followed the
> instructions here<http://www.geomoose.org/wiki/index.php/Setup_guide#Get_Identify_to_work_-_Make_sure_identify_will_work.when_you_identify_a_feature_any_visible_shape_file_or_WMS_will_display_those_attributes_in_the_table_of_contents.>,
> but I think these were written for Shapefiles, as I just get the text
> "[FEATURE_NAME]" in the resulting HTML rather than the actual feature
> selected name. This is also true if I put "[feature_name from table_name]"
> as per how fields are defined in the Mapserver DATA field.
> Any help much appreciated.
> Thanks
> Steve
> WhatsUp Gold - Download Free Network Management Software
> The most intuitive, comprehensive, and cost-effective network
> management toolset available today. Delivers lowest initial
> acquisition cost and overall TCO of any competing solution.
> http://p.sf.net/sfu/whatsupgold-sd
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110502/a364511d/attachment.html
More information about the Geomoose-users
