[Geomoose-users] Strange PHP error on Query
Dan Little
danlittle at yahoo.com
Tue May 3 15:27:38 EDT 2011
Oh, Doh, yeah, MapServer cannot automatically pick up the extent of a PostGIS layer. You need to specify it manually...
LAYER
... stuff ...
EXTENT minx,miny,maxx,maxy
... stuff ...
END
>________________________________
>From: Stephen Knox <stephenknox73 at gmail.com>
>To: Dan Little <danlittle at yahoo.com>
>Cc: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Tuesday, May 3, 2011 2:25 PM
>Subject: Re: [Geomoose-users] Strange PHP error on Query
> The data definitely maps OK. I can see it both in GeoMoose as a normal layer and in Mapserver. I can also see the calculated field with Identify. The problems just seems to be filtering/querying it.
>I wondered whether it's something to do with my version - I am using 2.4RC1 and I saw reference to bugs relating to certain functions in this release on the mailing list. I am also using Mapserver 5.6.3 for Fedora 14.
>The error seems to be coming in on the call to
>$queryLayer->queryByRect($queryLayer->getExtent());
>in query.php (around line 320)
>It's nothing to do with the getExtent function, as I tried putting my own values in there. I assume from the only related bug I could find that this the error message indicates the layer can't be queried because it's already open.
>Does that help track this down at all?
>Steve
>On Tue, May 3, 2011 at 1:03 PM, Dan Little <danlittle at yahoo.com> wrote:
>I think the querying it's doing is looking for metadata. Does this layer map okay? The error you're seeing is essentially "Ack, I'm MapServer and I can't figure out what the hell is going on with this layer!" Some easy stuff to try:
>>1) Ensure you can map the data.
>>2) Convert your inner query into a view and make sure there is a valid entry in geometry_columns for the view.
>>3) Curse aloud to others.
>>4) Repost to mailing list if none of the above works.
>>>To: geomoose-users at lists.sourceforge.net
>>>Sent: Monday, May 2, 2011 7:02 PM
>>>Excuse my inexperience but I have another query about getting query functionality to work in GeoMoose. It seems to be querying the database for a few seconds, then I get no Valid Response and the following error in PHP:
>>>httpd: mappostgis.c:1882: msPostGISLayerResultsGetShape: Assertion `layer->layerinfo != ((void *)0)' failed.
>>>I have the following section of mapbook:
>>> <service name="search_oas">
>>> <url>php/query.php</url>
>>> <step type="input">
>>> <input type="select" name="comparitor0" title="Percentage Travel by UG 2001">
>>> <option value="gt">Greater Than</option>
>>> <option value="eq">Equal To</option>
>>> <option value="lt">Less Than</option>
>>> </input>
>>> <input type="user" name="value0" title=""/>
>>> <input type="hidden" name="highlight" value="true"/>
>>> <input type="hidden" name="mode" value="search"/>
>>> <input type="hidden" name="layer0" value="uglines/oas"/>
>>> <input type="hidden" name="template0" value="itemquery"/>
>>> <input type="hidden" name="zoom_to_first" value="false"/>
>>> <input type="hidden" name="fieldname0" value="per_ttw_lu"/>
>>> </step>
>>> </service>
>>>and the layer definition below:
>>>LAYER
>>>CONNECTIONTYPE postgis
>>>NAME "oas"
>>>CONNECTION "user=postgres password=postgres dbname=lustations host=localhost"
>>>DATA "the_geom from (SELECT gid, the_geom, census_code, ttw_by_lu, (ttw_by_lu::REAL/tot_pop::REAL)*100 as per_ttw_lu, tot_pop FROM oa_data) as foo using srid=27700 using unique gid"
>>>STATUS ON
>>>TYPE POLYGON
>>>METADATA
>>>identify_record "identify_oas.html"
>>>itemquery "oa_itemquery.html"
>>>END
>>>CLASS
>>> STYLE
>>> OUTLINECOLOR 0 0 0
>>> #COLOR 216 250 138
>>> WIDTH 1
>>> END
>>>END
>>>END
>>>my oa_itemquery.html looks like this:
>>><!-- MapServer Template -->
>>><tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Output Areas</u></b></tr>
>>><tr>
>>><td align="right"><b>Census Code:</b></td>
>>><td>[census_code]</td>
>>></tr>
>>><tr>
>>><td align="right"><b>Percentage travel by LU:</b></td>
>>><td>[per_ttw_lu]</td>
>>></tr>
>>><tr>
>>><td> </td>
>>><td> </td>
>>></tr>
>>>WhatsUp Gold - Download Free Network Management Software
>>>The most intuitive, comprehensive, and cost-effective network
>>>management toolset available today. Delivers lowest initial
>>>acquisition cost and overall TCO of any competing solution.
>>>http://p.sf.net/sfu/whatsupgold-sd
>>>_______________________________________________
>>>Geomoose-users mailing list
>>>Geomoose-users at lists.sourceforge.net
>>>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110503/b49284b6/attachment.html
More information about the Geomoose-users
