[Geomoose-users] Loading on server
    Jacob Rodel
    jacob.rodel at co.todd.mn.us
    Fri May 13 10:55:17 EDT 2011
When I hit print It will actually will put files in the tmp folder on the server but they have a file size of zero.   I then receive this error:
Fatal error: Maximum execution time of 30 seconds exceeded in E:\ms4w\apps\toddcounty\htdocs\php\print_util.php on line 52
If I turn off most of the layers I do not receive an error but don’t get the download option.  The information tab is just blank.  Is there a way I can troubleshoot this somehow?
Jake Rodel
GIS Technician
Todd County GIS & Land Services Dept.
347 Central Ave Suite 1
Long Prairie, MN 56347
(320) 732-4248
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Friday, May 13, 2011 9:31 AM
To: Jacob Rodel; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Loading on server
Jake,
It sounds like you have a relative link that should be an explicit link or vice-versa for those services.
Is the TMP location identified explicitly on your machine vs the remote server it's being installed on?  I believe the results for the search and possibly the PDF output are placed in a temp location for display, and this location may be different between machines.  Of defaults to a different location.
bobb
>>> "Jacob Rodel" <jacob.rodel at co.todd.mn.us> wrote:
I am having a couple weird issues trying to setup our application on the server and was just wondering if anybody had any insight as to what I might be overlooking.  When I run on my hard drive everything works fine but when our IT loads it on the server the print service doesn’t return the option to download the pdf.  Also when you search for taxpayers it selects and highlight the parcels but does not display the results in the information tab.  All that you get is the header.
Jake Rodel
GIS Technician
(320) 732-4248
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110513/b206f13e/attachment.html
More information about the Geomoose-users
