[Geomoose-users] Calling javascript from mapbook.xml,
 or change params with javascript
    Brent Fraser
    bfraser at geoanalytic.com
    Thu May 26 10:49:02 EDT 2011
Just a note for those trying to do the same thing.  Bob was successful
when he changed his function name to be all lowercase.
Best Regards,
Brent Fraser
On 5/24/2011 8:34 AM, Brent Fraser wrote:
> Bob,
>   Have a look at http://www.geomoose.org/docs/user_extensions.html and
> varoius pages on the wiki
> (http://www.geomoose.org/wiki/index.php/Main_Page), and the functions
> defined in the geomoose.js file.  The functions in the file are the
> user-accessible "official" GeoMOOSE API.  These resources may give you
> a few ideas.
> In one of my sites,  I needed to get the value of the selected item in
> a combo box and use it for input value in services.
> My combo box is a little complicated; the important bits are
> id="GA_SelectedImage" and the first part of the option value (1,2,3,etc)
> <div id="control-panel">
> <center>
>         Image:
> <select id="GA_SelectedImage"
> onchange="GeoMOOSE.UX.registered_extensions.GA_ImageOps.prototype.zoomToImage(this.value);">
> <option value="">Choose Image:</option>
> <option
> value="1:-2172034,13348962,-1027313,14456993:Landsat/p230r005_20010703">L7
> 2001-07-03 p230-r005</option>
> <option
> value="2:-2564614,12851203,-1468813,13863841:Landsat/p230r006_20010703">L7
> 2001-07-03 p230-r006</option>
> <option
> value="3:-2564614,12851203,-1468813,13863841:Landsat/p231r006_20010608">L7
> 2001-06-08 p231-r006</option>
> I have a service called "add_polygon" (see the Feature Editor doc)
> where one of the inputs is defined as "imageid":
> <service name="add_polygon">
> <input type="ga_get_imageid" name="feature:imageid" value="0"/>
> Note the type tag value refers to my custom input type.  And [I
> think?] since its outside the the "<step>" tag it is not shown to the
> user.  If I wanted to make it visible and changeable by the user I
> could have done:
> <step type="input">
> I defined the type by creating a Javascript file in the extensions
> folder containing:
> GeoMOOSE.Services.InputType.GetImageID =
> OpenLayers.Class(GeoMOOSE.Services.InputType, {
>     MAPBOOK_NAME: "ga_get_imageid",
>      getValue: function() {
>         var selection = document.getElementById('GA_SelectedImage');
>         var theValue = selection.children[selection.selectedIndex].value;
>         var aParams = theValue.split(':');
>         var id = aParams[0];
>         return id;
> And my JavaScript file is loaded in my main html page:
> <script type="text/javascript"
> src="extensions/GeoAnalytic_Custom.js"></script>
> So basically, when the service is invoked, it processes the input
> types, and calls the ga_get_imageid function.  The function finds the
> combo box control, gets the selected value, and returns the important
> part of the value.  GeoMoose sets the service's input type value to
> that returned value and passes it to the target URL of the service.
> Somewhat complicated, but it separates my custom JavaScript from the
> standard GeoMOOSE (making updates much easier).
> Best Regards,
> Brent Fraser
> On 5/23/2011 12:11 PM, Bistrais, Bob wrote:
>> Hi,
>> I'm looking to dynamically control some of the parameter values in
>> mapbook.xml.  In a nutshell, I've been able to save a selected town
>> name by holding it in a hidden input in index.html.  So what I'd like
>> to do, in the search_parcels service, is to update a parameter with
>> that town name.  I believe it would make use of some javascript, but
>> I'm not quite sure how to do it.  Any suggestions?  Any more
>> clarification needed?
> vRanger cuts backup time in half-while increasing security.
> With the market-leading solution for virtual backup and recovery,
> you get blazing-fast, flexible, and affordable data protection.
> Download your free trial now.
> http://p.sf.net/sfu/quest-d2dcopy1
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110526/1819f9d0/attachment.html
More information about the Geomoose-users
