[Geomoose-users] Problem adding a link to the identify results
Ed Boesenberg, III boesiii at yahoo.com
Wed Nov 9 16:33:42 EST 2011
Thanks, that worked.  I don't know how the back-double-quotes even got
there, I don't know how to type them in either.
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Wednesday, November 09, 2011 4:13 PM
To: Ed Boesenberg, III
Cc: 'Ed Boesenberg'; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Problem adding a link to the identify results
Ed,
  IE is not very forgiving with HTML that deviates from the spec.  I changed
the back-double-quote (") to a forward?-double-quote (") and it rendered
properly.
Best Regards,
Brent Fraser
On 11/9/2011 1:21 PM, Ed Boesenberg, III wrote:
I mean that no text is being rendered.  It is being rendered if I DO NOT
place my code, as shown in the previous email, into the identify html.
It worked in GM 2.0 but not the current GM 2.4 version.
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Wednesday, November 09, 2011 1:05 PM
To: Ed Boesenberg
Cc: geomoose-users at lists.osgeo.org
If you mean the PIN is not being substituted, it needs to be lowercase for a
database column name but uppercase for a shapefile field (a Mapserver
thing).  If you mean no text at all is being rendered, likely mapserver
can't find indentify.html ?
Best Regards,
Brent Fraser
On 11/9/2011 10:53 AM, Ed Boesenberg wrote:
Why do results not show up in the Information tab if the code below is added
to an identify html file or popup html file?
<tr>
<td> <a href=
<http://www2.county.allegheny.pa.us/RealEstate/GeneralInfo.aspx?ParcelID=%5b
PIN%5d>
"http://www2.county.allegheny.pa.us/RealEstate/GeneralInfo.aspx?ParcelID=[PI
N]" target="_blank">See Owner Info on Allegheny County Website</a></td>
</tr>
Thanks,
Ed Boesenberg
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111109/9f198b23/attachment.html
More information about the Geomoose-users mailing list
