[Geomoose-users] Problem adding a link to the identify results
Brent Fraser
bfraser at geoanalytic.com
Wed Nov 9 16:39:02 EST 2011
Some document editors (e.g. Word) "help" you by changing text. I like
using Notepad++ to keep it simple. It colorizes the text so I can tell
if things are commented out or quoted, and it highlights open/closing
tags in html and xml.
Best Regards,
Brent Fraser
On 11/9/2011 2:33 PM, Ed Boesenberg, III wrote:
> Thanks, that worked. I don't know how the back-double-quotes even got
> there, I don't know how to type them in either.
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Wednesday, November 09, 2011 4:13 PM
> *To:* Ed Boesenberg, III
> *Cc:* 'Ed Boesenberg'; geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Problem adding a link to the identify
> results
> Ed,
> IE is not very forgiving with HTML that deviates from the spec. I
> changed the back-double-quote (") to a forward?-double-quote (") and
> it rendered properly.
> Best Regards,
> Brent Fraser
> On 11/9/2011 1:21 PM, Ed Boesenberg, III wrote:
> I mean that no text is being rendered. It is being rendered if I DO
> NOT place my code, as shown in the previous email, into the identify
> html.
> It worked in GM 2.0 but not the current GM 2.4 version.
> *From:*geomoose-users-bounces at lists.osgeo.org
> <mailto:geomoose-users-bounces at lists.osgeo.org>
> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Brent
> Fraser
> *Sent:* Wednesday, November 09, 2011 1:05 PM
> *To:* Ed Boesenberg
> *Cc:* geomoose-users at lists.osgeo.org
> <mailto:geomoose-users at lists.osgeo.org>
> results
> If you mean the PIN is not being substituted, it needs to be lowercase
> for a database column name but uppercase for a shapefile field (a
> Mapserver thing). If you mean no text at all is being rendered,
> likely mapserver can't find indentify.html ?
> Best Regards,
> Brent Fraser
> On 11/9/2011 10:53 AM, Ed Boesenberg wrote:
> Why do results not show up in the Information tab if the code below is
> added to an identify html file or popup html file?
> <tr>
> <td> <a
> href="http://www2.county.allegheny.pa.us/RealEstate/GeneralInfo.aspx?ParcelID=[PIN]"
> <http://www2.county.allegheny.pa.us/RealEstate/GeneralInfo.aspx?ParcelID=%5bPIN%5d>
> target="_blank">See Owner Info on Allegheny County Website</a></td>
> </tr>
> Thanks,
> Ed Boesenberg
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111109/2bdd39a3/attachment-0001.html
More information about the Geomoose-users
