[Geomoose-users] Item Query Problems and Question
    Ed Boesenberg, III
    boesiii at yahoo.com
    Thu Nov 10 16:31:11 EST 2011
Brent,
Not sure if this helps but below is the text from ms_error.txt:
[Thu Nov 10 16:29:44 2011].601000 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Thu Nov 10 16:29:44 2011].601000 msDrawMap(): Layer 0 (ftma_waterlines),
0.000s
[Thu Nov 10 16:29:44 2011].601000 msDrawMap(): Drawing Label Cache, 0.000s
[Thu Nov 10 16:29:44 2011].601000 msDrawMap() total time: 0.001s
[Thu Nov 10 16:29:44 2011].738000 msSaveImage() total time: 0.137s
[Thu Nov 10 16:29:44 2011].741000 msSaveImage() total time: 0.001s
[Thu Nov 10 16:29:44 2011].742000 msLayerGetShape(): Shapefile error.
Shapefile layer has not been opened.
[Thu Nov 10 16:29:44 2011].743000 msFreeMap(): freeing map at 038DB8A0.
[Thu Nov 10 16:29:44 2011].832000 CGI Request 1 on process 5960
[Thu Nov 10 16:29:44 2011].838000 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Thu Nov 10 16:29:44 2011].851000 msDrawMap(): Layer 0 (ftma_waterlines),
0.013s
[Thu Nov 10 16:29:44 2011].851000 msDrawMap(): Drawing Label Cache, 0.000s
[Thu Nov 10 16:29:44 2011].851000 msDrawMap() total time: 0.019s
[Thu Nov 10 16:29:45 2011].231000 msSaveImage() total time: 0.380s
[Thu Nov 10 16:29:45 2011].234000 mapserv request processing time (loadmap
not incl.): 0.402s
[Thu Nov 10 16:29:45 2011].234000 msFreeMap(): freeing map at 01E1CA60.
[Thu Nov 10 16:29:44 2011].914000 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Thu Nov 10 16:29:44 2011].914000 msDrawMap(): Layer 0 (ftma_waterlines),
0.000s
[Thu Nov 10 16:29:44 2011].914000 msDrawMap(): Drawing Label Cache, 0.000s
[Thu Nov 10 16:29:44 2011].914000 msDrawMap() total time: 0.005s
[Thu Nov 10 16:29:45 2011].81000 msSaveImage() total time: 0.167s
[Thu Nov 10 16:29:45 2011].85000 msSaveImage() total time: 0.002s
[Thu Nov 10 16:29:45 2011].85000 msLayerGetShape(): Shapefile error.
[Thu Nov 10 16:29:45 2011].505000 msFreeMap(): freeing map at 03966668.
Ed
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Thursday, November 10, 2011 3:35 PM
To: boesiii
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Item Query Problems and Question
Try adding
DEBUG 5
to the mapfile and checking the messages in ms_error.txt
Best Regards,
Brent Fraser
On 11/10/2011 1:23 PM, boesiii wrote:
> I tried to debug using firebug but didn't see anything obvious.  The code
> below is a result from the Firebug console:
> <results><html></html></results>
> For some reason I don't think it is reading my
> "ftma_waterlines_itemquery.html" but I am not positive.
http://geomoose-users.964460.n3.nabble.com/Geomoose-users-Item-Query-Problem
s-and-Question-tp3497288p3497875.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
