[Geomoose-users] Item Query Problems and Question
    Dan Little
    danlittle at yahoo.com
    Tue Nov 29 13:44:27 EST 2011
Do you have the magic string "<!-- MapServer Template -->" in your template file?
>________________________________
> From: "Ed Boesenberg, III" <boesiii at yahoo.com>
>To: 'Brent Fraser' <bfraser at geoanalytic.com>
>Cc: geomoose-users at lists.osgeo.org
>Sent: Thursday, November 10, 2011 3:31 PM
>Subject: RE: [Geomoose-users] Item Query Problems and Question
>Brent,
>Not sure if this helps but below is the text from ms_error.txt:
>[Thu Nov 10 16:29:44 2011].601000 msDrawMap(): WMS/WFS set-up and query,
>0.000s
>[Thu Nov 10 16:29:44 2011].601000 msDrawMap(): Layer 0 (ftma_waterlines),
>0.000s
>[Thu Nov 10 16:29:44 2011].601000 msDrawMap(): Drawing Label Cache, 0.000s
>[Thu Nov 10 16:29:44 2011].601000 msDrawMap() total time: 0.001s
>[Thu Nov 10 16:29:44 2011].738000 msSaveImage() total time: 0.137s
>[Thu Nov 10 16:29:44 2011].741000 msSaveImage() total time: 0.001s
>[Thu Nov 10 16:29:44 2011].742000 msLayerGetShape(): Shapefile error.
>Shapefile layer has not been opened.
>[Thu Nov 10 16:29:44 2011].743000 msFreeMap(): freeing map at 038DB8A0.
>[Thu Nov 10 16:29:44 2011].832000 CGI Request 1 on process 5960
>[Thu Nov 10 16:29:44 2011].838000 msDrawMap(): WMS/WFS set-up and query,
>0.000s
>[Thu Nov 10 16:29:44 2011].851000 msDrawMap(): Layer 0 (ftma_waterlines),
>0.013s
>[Thu Nov 10 16:29:44 2011].851000 msDrawMap(): Drawing Label Cache, 0.000s
>[Thu Nov 10 16:29:44 2011].851000 msDrawMap() total time: 0.019s
>[Thu Nov 10 16:29:45 2011].231000 msSaveImage() total time: 0.380s
>[Thu Nov 10 16:29:45 2011].234000 mapserv request processing time (loadmap
>not incl.): 0.402s
>[Thu Nov 10 16:29:45 2011].234000 msFreeMap(): freeing map at 01E1CA60.
>[Thu Nov 10 16:29:44 2011].914000 msDrawMap(): WMS/WFS set-up and query,
>0.000s
>[Thu Nov 10 16:29:44 2011].914000 msDrawMap(): Layer 0 (ftma_waterlines),
>0.000s
>[Thu Nov 10 16:29:44 2011].914000 msDrawMap(): Drawing Label Cache, 0.000s
>[Thu Nov 10 16:29:44 2011].914000 msDrawMap() total time: 0.005s
>[Thu Nov 10 16:29:45 2011].81000 msSaveImage() total time: 0.167s
>[Thu Nov 10 16:29:45 2011].85000 msSaveImage() total time: 0.002s
>[Thu Nov 10 16:29:45 2011].85000 msLayerGetShape(): Shapefile error.
>[Thu Nov 10 16:29:45 2011].505000 msFreeMap(): freeing map at 03966668.
>Ed
>-----Original Message-----
>From: Brent Fraser [mailto:bfraser at geoanalytic.com]
>Sent: Thursday, November 10, 2011 3:35 PM
>To: boesiii
>Subject: Re: [Geomoose-users] Item Query Problems and Question
>Try adding
>DEBUG 5
>to the mapfile and checking the messages in ms_error.txt
>Best Regards,
>Brent Fraser
>On 11/10/2011 1:23 PM, boesiii wrote:
>> I tried to debug using firebug but didn't see anything obvious.  The code
>> below is a result from the Firebug console:
>> <results><html></html></results>
>> For some reason I don't think it is reading my
>> "ftma_waterlines_itemquery.html" but I am not positive.
>> View this message in context:
>http://geomoose-users.964460.n3.nabble.com/Geomoose-users-Item-Query-Problem
>s-and-Question-tp3497288p3497875.html
>> Sent from the Geomoose-users mailing list archive at Nabble.com.
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111129/7ef6a2ad/attachment-0001.html
More information about the Geomoose-users
