[Geomoose-users] geomoose on 64 bit
    Jim Hagedorn
    jhagedorn at bannerassociates.com
    Mon Nov 21 11:51:06 EST 2011
Brent
So if that line is in the mapbook, what else could the problem be?  It is the second line in the mapbook.
Thanks
jim
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Monday, November 21, 2011 10:49 AM
To: Jim Hagedorn
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] geomoose on 64 bit
That line is trying to parse the mapbook.xml looking for a "version" attribute on the mapbook tag:
<mapbook version="2.0">
Best Regards,
Brent Fraser
On 11/21/2011 9:40 AM, Jim Hagedorn wrote:
Brent
This is in the debugger
HTML1201: localhost is a website you've added to Compatibility View.
egan.php
SCRIPT5007: Unable to get value of the property 'getAttribute': object is null or undefined
main.js, line 277 character 3
There isn't a ms_error.txt file.
Thanks
jim
Sent: Monday, November 21, 2011 10:33 AM
To: Jim Hagedorn
Cc: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Jim,
  If Geomoose is rendering the buttonbar, catalog, etc, but not any map graphics, the problem is likely with the mapserver configuration.  Use the browser debugger to see the response sent by mapserver (it could be an error message instead of an image).   And there might be some info in C:\ms4w\tmp\ms_error.txt
Best Regards,
Brent Fraser
On 11/21/2011 9:28 AM, Jim Hagedorn wrote:
Brent
I had found that on Friday.  I can get the demo to work but the clients page doesn't come up.  I get the wrapper but no map.  I have gone to the phpinfo.php page and it comes up so I figure that php is working.  And the error log (f12) don't show any more errors.  I'm using ms4w 2.3.1 and geomoose 2.4.  I have been able to get it to work using gm2.2 but then was having issues with the identify.  So I'm still stuck getting my client up and running again.
Thanks
jim
Sent: Monday, November 21, 2011 10:08 AM
To: Jim Hagedorn
Jim,
  Same problem: on main.js's line 501, there's a trailing comma (delete it).
Best Regards,
Brent Fraser
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111121/b6bd6bb6/attachment.html
More information about the Geomoose-users
