[Geomoose-users] geomoose on 64 bit
Brent Fraser
bfraser at geoanalytic.com
Mon Nov 21 12:00:29 EST 2011
Jim,
I'm not sure. Since the buttonbar is showing buttons, your
mapbook.xml IS being loaded and parsed, so how Geomoose can fail on line
277 is a mystery to me.
Which version of IE are you using? Can you try Chrome (or Firefox)?
Best Regards,
Brent Fraser
On 11/21/2011 9:51 AM, Jim Hagedorn wrote:
> Brent
> So if that line is in the mapbook, what else could the problem be? It
> is the second line in the mapbook.
> Thanks
> jim
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Monday, November 21, 2011 10:49 AM
> *To:* Jim Hagedorn
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] geomoose on 64 bit
> That line is trying to parse the mapbook.xml looking for a "version"
> attribute on the mapbook tag:
> <mapbook version="2.0">
> Best Regards,
> Brent Fraser
> On 11/21/2011 9:40 AM, Jim Hagedorn wrote:
> Brent
> This is in the debugger
> HTML1201: localhost is a website you've added to Compatibility View.
> egan.php
> SCRIPT5007: Unable to get value of the property 'getAttribute': object
> is null or undefined
> main.js, line 277 character 3
> There isn't a ms_error.txt file.
> Thanks
> jim
> *Sent:* Monday, November 21, 2011 10:33 AM
> *To:* Jim Hagedorn
> <mailto:geomoose-users at lists.osgeo.org>
> Jim,
> If Geomoose is rendering the buttonbar, catalog, etc, but not any
> map graphics, the problem is likely with the mapserver configuration.
> Use the browser debugger to see the response sent by mapserver (it
> could be an error message instead of an image). And there might be
> some info in C:\ms4w\tmp\ms_error.txt
> Best Regards,
> Brent Fraser
> On 11/21/2011 9:28 AM, Jim Hagedorn wrote:
> Brent
> I had found that on Friday. I can get the demo to work but the
> clients page doesn't come up. I get the wrapper but no map. I have
> gone to the phpinfo.php page and it comes up so I figure that php is
> working. And the error log (f12) don't show any more errors. I'm
> using ms4w 2.3.1 and geomoose 2.4. I have been able to get it to work
> using gm2.2 but then was having issues with the identify. So I'm
> still stuck getting my client up and running again.
> Thanks
> jim
> *Sent:* Monday, November 21, 2011 10:08 AM
> *To:* Jim Hagedorn
> Jim,
> Same problem: on main.js's line 501, there's a trailing comma
> (delete it).
> Best Regards,
> Brent Fraser
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111121/be2c74a7/attachment-0001.html
More information about the Geomoose-users
