[Geomoose-users] geomoose on 64 bit
    Brent Fraser
    bfraser at geoanalytic.com
    Mon Nov 21 14:24:46 EST 2011
Jim K.,
Maybe.  I don't know how many others are having this problem (I would
expect everyone given that IE is so widely used).
Best Regards,
Brent Fraser
On 11/21/2011 10:06 AM, Jim Klassen wrote:
> I know we are really close to a 2.6 release, but Is this something we
> should fix with a 2.4.1 release?
> On Nov 21, 2011, at 10:08 AM, Brent Fraser wrote:
>> Jim,
>>   Same problem: on main.js's line 501, there's a trailing comma
>> (delete it).
>> Best Regards,
>> Brent Fraser
>> On 11/18/2011 9:25 AM, Jim Hagedorn wrote:
>>> Brent
>>> The demo started working but the clients page still isn’t showing
>>> the map.  The clients page is a php page because we are going to use
>>> a login screen.
>>> So this is the errors on the egan.php page
>>> SCRIPT1028: Expected identifier, string or number
>>> main.js, line 502 character 5
>>> SCRIPT5007: The value of the property 'main' is null or undefined,
>>> not a Function object
>>> egan.php, line 66 character 1
>>> Thanks
>>> jim
>>> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
>>> *Sent:* Friday, November 18, 2011 9:55 AM
>>> *To:* Jim Hagedorn
>>> *Cc:* geomoose-users at lists.osgeo.org
>>> *Subject:* Re: [Geomoose-users] geomoose on 64 bit
>>> Jim,
>>>   From an old email
>>> (http://www.osgeo.org/pipermail/geomoose-users/2011-June/003117.html) :
>>>   For GeoMOOSE, I had to remove the trailing comma on line 2216 of
>>> compiled.js to get:
>>>                     resolutions: CONFIGURATION.scales
>>> Best Regards,
>>> Brent Fraser
>>> On 11/18/2011 8:50 AM, Jim Hagedorn wrote:
>>> Brent
>>> This is the error messages
>>> compiled.js, line 2217 character 5
>>> geomoose.html, line 72 character 1
>>> jim
>>> *Sent:* Friday, November 18, 2011 9:46 AM
>>> *To:* Jim Hagedorn
>>> <mailto:geomoose-users at lists.osgeo.org>
>>> Jim,
>>>   IE is very picky about parsing HTML.  It has a debugger (F12).
>>> Best Regards,
>>> Brent Fraser
>>> On 11/18/2011 8:43 AM, Jim Hagedorn wrote:
>>> Brent
>>> When I bring up firefox to use the debugger, the map comes up.  So
>>> it’s something to do with IE.    I’m going to reinstall 2.2 on the
>>> clients machine and be done with it until I can get this figured out.
>>> Thanks
>>> jim
>>> *Sent:* Friday, November 18, 2011 9:33 AM
>>> *To:* Jim Hagedorn
>>> Jim,
>>>   What does your browser debugger report for the getmapbook.php request?
>>> Best Regards,
>>> Brent Fraser
>>> On 11/18/2011 7:35 AM, Jim Hagedorn wrote:
>>> Brent
>>> Reloaded the geomoose 2.4 and ms4w 2.3.1 and went to the phpinfo.php
>>> and it came right up.  I still only get the green on the demo.  With
>>> 2.2 I atleast got the map to come up.
>>> Thanks
>>> jim
>>> *Sent:* Thursday, November 17, 2011 4:17 PM
>>> *To:* Jim Hagedorn
>>> *Cc:* Ed Boesenberg; geomoose-users at lists.osgeo.org
>>> If you get just the green banner without the button bar, that
>>> usually means mapbook.xml file has not been sent to the client, and
>>> the most likely candidate is a problem with PHP. since the mapbook
>>> is sent via getmapbook.php.   If you want to check this, have a look
>>> at http://www.geomoose.org/howto/getmapbook.html, or simply try
>>> http://localhost/phpinfo.php
>>> Best Regards,
>>> Brent Fraser
>>> On 11/17/2011 2:36 PM, Jim Hagedorn wrote:
>>> The error logs didn’t tell me anything.  As for as I could read as
>>> soon as the green page came up without the map, it thought it was
>>> working and hence no errors.  I am using the plain geomoose.  I keep
>>> deleting the ms4w directory and uninstall apache every time I reload
>>> a different version.  I would just like to know why 2.4 doesn’t seem
>>> to work with windows 7.  The 2.2 works just fine.
>>> If ducky is listening, what do you think?
>>> Thanks
>>> jim
>>> *From:*Ed Boesenberg [mailto:eboesenberg at niraengineers.com]
>>> *Sent:* Thursday, November 17, 2011 3:31 PM
>>> *To:* Jim Hagedorn; geomoose-users at lists.osgeo.org
>>> *Subject:* RE: [Geomoose-users] geomoose on 64 bit
>>> Did the error logs tell you anything?  Are you using the Web
>>> Mercator Demo or plain GeoMoose?
>>> You can have two versions of GeoMoose running, let me know if you
>>> would like instructions.
>>> *From:*Jim Hagedorn [mailto:jhagedorn at bannerassociates.com]
>>> *Sent:* Thursday, November 17, 2011 4:11 PM
>>> *To:* Ed Boesenberg; geomoose-users at lists.osgeo.org
>>> Ok I finally got it to work on windows 7.  I had to go back to
>>> geomoose 2.2 and ms4w 2.3.1 to finally get it all working.  So any
>>> idea why geomoose 2.4 wouldn’t work with windows 7?
>>> Thanks
>>> jim
>>> *Sent:* Thursday, November 17, 2011 12:10 PM
>>> I have GeoMoose 2.4 and MS4W 3.0.1 running on Windows 7 64bit.  I
>>> didn't have to do anything special to get it up and running besides
>>> unzipping the GeoMoose and MS4W files and installing Apache using
>>> the batch file.  To check and see if MapServer is running, open your
>>> web browser and type 127.0.0.1 in the address and you should see
>>> something similar to the attached image file.
>>> Ed Boesenberg
>>> *From:*geomoose-users-bounces at lists.osgeo.org
>>> <mailto:geomoose-users-bounces at lists.osgeo.org>
>>> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Jim
>>> Hagedorn
>>> *Sent:* Thursday, November 17, 2011 12:38 PM
>>> *To:* geomoose-users at lists.osgeo.org
>>> *Subject:* [Geomoose-users] geomoose on 64 bit
>>> I have a client that got a new computer and I need to reinstall
>>> geomoose.  Have spent 2 hours trying to get it running.  Have
>>> installed it twice.  I can get the Apache server to work and the web
>>> page comes up but there is no map.  How do I check to see if
>>> mapserver is working?  That what seems to me to be the issue.  It is
>>> windows 7 with 64 bit.
>>> Thanks
>>> jim
>>> Jim Hagedorn
>>> GIS Specialist
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111121/3d7604cc/attachment-0001.html
More information about the Geomoose-users
