[Geomoose-users] geomoose on 64 bit
    Jim Hagedorn
    jhagedorn at bannerassociates.com
    Mon Nov 21 15:25:34 EST 2011
Brent
I was about to give up when everything started working.  I think it I boil it down, it was the compiled.js and the main.js with the extra commas.  Now I will see if I can get it to work on the clients machine tomorrow.
Thanks for all your help.
jim
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Monday, November 21, 2011 1:25 PM
To: Jim Klassen
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] geomoose on 64 bit
Jim K.,
Maybe.  I don't know how many others are having this problem (I would expect everyone given that IE is so widely used).
Best Regards,
Brent Fraser
On 11/21/2011 10:06 AM, Jim Klassen wrote:
I know we are really close to a 2.6 release, but Is this something we should fix with a 2.4.1 release?
On Nov 21, 2011, at 10:08 AM, Brent Fraser wrote:
Jim,
  Same problem: on main.js's line 501, there's a trailing comma (delete it).
Best Regards,
Brent Fraser
On 11/18/2011 9:25 AM, Jim Hagedorn wrote:
Brent
The demo started working but the clients page still isn't showing the map.  The clients page is a php page because we are going to use a login screen.
So this is the errors on the egan.php page
SCRIPT1028: Expected identifier, string or number
main.js, line 502 character 5
SCRIPT5007: The value of the property 'main' is null or undefined, not a Function object
egan.php, line 66 character 1
Thanks
jim
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Friday, November 18, 2011 9:55 AM
To: Jim Hagedorn
Cc: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Jim,
  From an old email (http://www.osgeo.org/pipermail/geomoose-users/2011-June/003117.html) :
  For GeoMOOSE, I had to remove the trailing comma on line 2216 of compiled.js to get:
                    resolutions: CONFIGURATION.scales
Best Regards,
Brent Fraser
On 11/18/2011 8:50 AM, Jim Hagedorn wrote:
Brent
This is the error messages
compiled.js, line 2217 character 5
geomoose.html, line 72 character 1
jim
Sent: Friday, November 18, 2011 9:46 AM
To: Jim Hagedorn
Jim,
  IE is very picky about parsing HTML.  It has a debugger (F12).
Best Regards,
Brent Fraser
On 11/18/2011 8:43 AM, Jim Hagedorn wrote:
Brent
When I bring up firefox to use the debugger, the map comes up.  So it's something to do with IE.    I'm going to reinstall 2.2 on the clients machine and be done with it until I can get this figured out.
Thanks
jim
Sent: Friday, November 18, 2011 9:33 AM
To: Jim Hagedorn
Jim,
  What does your browser debugger report for the getmapbook.php request?
Best Regards,
Brent Fraser
On 11/18/2011 7:35 AM, Jim Hagedorn wrote:
Brent
Reloaded the geomoose 2.4 and ms4w 2.3.1 and went to the phpinfo.php and it came right up.  I still only get the green on the demo.  With 2.2 I atleast got the map to come up.
Thanks
jim
Sent: Thursday, November 17, 2011 4:17 PM
To: Jim Hagedorn
Cc: Ed Boesenberg; geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
If you get just the green banner without the button bar, that usually means mapbook.xml file has not been sent to the client, and the most likely candidate is a problem with PHP. since the mapbook is sent via getmapbook.php.   If you want to check this, have a look at http://www.geomoose.org/howto/getmapbook.html, or simply try http://localhost/phpinfo.php
Best Regards,
Brent Fraser
On 11/17/2011 2:36 PM, Jim Hagedorn wrote:
The error logs didn't tell me anything.  As for as I could read as soon as the green page came up without the map, it thought it was working and hence no errors.  I am using the plain geomoose.  I keep deleting the ms4w directory and uninstall apache every time I reload a different version.  I would just like to know why 2.4 doesn't seem to work with windows 7.  The 2.2 works just fine.
If ducky is listening, what do you think?
Thanks
jim
From: Ed Boesenberg [mailto:eboesenberg at niraengineers.com]
Sent: Thursday, November 17, 2011 3:31 PM
To: Jim Hagedorn; geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: RE: [Geomoose-users] geomoose on 64 bit
Did the error logs tell you anything?  Are you using the Web Mercator Demo or plain GeoMoose?
You can have two versions of GeoMoose running, let me know if you would like instructions.
From: Jim Hagedorn [mailto:jhagedorn at bannerassociates.com]
Sent: Thursday, November 17, 2011 4:11 PM
To: Ed Boesenberg; geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Ok I finally got it to work on windows 7.  I had to go back to geomoose 2.2 and ms4w 2.3.1 to finally get it all working.  So any idea why geomoose 2.4 wouldn't work with windows 7?
Thanks
jim
Sent: Thursday, November 17, 2011 12:10 PM
I have GeoMoose 2.4 and MS4W 3.0.1 running on Windows 7 64bit.  I didn't have to do anything special to get it up and running besides unzipping the GeoMoose and MS4W files and installing Apache using the batch file.  To check and see if MapServer is running, open your web browser and type 127.0.0.1 in the address and you should see something similar to the attached image file.
Ed Boesenberg
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Jim Hagedorn
Sent: Thursday, November 17, 2011 12:38 PM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] geomoose on 64 bit
I have a client that got a new computer and I need to reinstall geomoose.  Have spent 2 hours trying to get it running.  Have installed it twice.  I can get the Apache server to work and the web page comes up but there is no map.  How do I check to see if mapserver is working?  That what seems to me to be the issue.  It is windows 7 with 64 bit.
Thanks
jim
Jim Hagedorn
GIS Specialist
http://lists.osgeo.org/mailman/listinfo/geomoose-users
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111121/b2c67f83/attachment-0001.html
More information about the Geomoose-users
