[Geomoose-users] PSC Update: Progress on Versioned Docs
Dan Little danlittle at yahoo.com
Tue Nov 29 13:15:30 EST 2011
Most of those problems were learning curve issues for me:
1) Learning to manage a project in the wild.
2) Learning to manage a project where versions and source revision are important.
3) Learning to be diligent with releases.
Via GeoMoose (I miss my "MOOSE") and other projects I've gotten more disciplined about it but I think for 2.6 and the future the PSC should appoint a release manager and for 2.6 we should develop the "release checklist" to make sure that all of the SOP is followed before making something official.
>________________________________
> From: Brent Fraser <bfraser at geoanalytic.com>
>To: James Klassen <klassen.js at gmail.com>
>Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
>Sent: Monday, November 28, 2011 4:54 PM
>Subject: Re: [Geomoose-users] PSC Update: Progress on Versioned Docs
>Jim,
>  I'm sure I don't understand all the ramifications of what you've
    written, but one thing I'd insist on is the tag rule: if we release
    it, it gets tagged.  Otherwise support gets too hard....
>Best Regards,
Brent Fraser
>On 11/28/2011 9:07 AM, James Klassen wrote:
>Personally, I would like to see SVN reorganized to follow the general standard form for /trunk /branches and /tags.  Besides being less confusing for developers from other projects, this will make use of hg/git/bzr as clients to the svn repository much easier for those who like to develop offline or maintain site-specific local branches.  I'm thinking the best time to do this is when the repository is moved over to OSGEO hosting from SF.net, since everyone will need to switch or re-checkout anyway.
>>I'm thinking something along the lines of
>>/moose
>> /trunk
>> /branches
>> /tags
>>  /1.0
>>  /1.1
>>  /1.4
>>  /1.6 (this currently doesn't exist in SVN, but IIRC we released it)
>>/moose2
>> /trunk
>> /branches (used to add changes to older version of the code like the 2.4.1 fixes we've been discussing)
>>  /2.0
>>  /2.2 (also not currently in SVN)
>>  /2.4
>> /tags (the rule is if it gets released, it gets tagged)
>>  /2.0
>>  /2.4
>>  /2.4.1
>>  /current
>>As far as I know, my /moose2-branches/url_mapbook-jk is way out of date and doesn't have value anymore and can be deleted.  I'm not sure what /sandbox-len is?
>>On Mon, Nov 28, 2011 at 8:55 AM, Dan Little <danlittle at yahoo.com> wrote:
>>You can see the differences here:
>>>- http://www.geomoose.org/2.4/
>>>- http://www.geomoose.org/2.4/api/
>>>- http://www.geomoose.org/trunk/
>>>- http://www.geomoose.org/trunk/api/
>>>Right now "/" points to a different directory
                  altogether called "snapshot_20111128", until this
                  morning "/" pointed the docs built from trunk.  Back
                  in Denver we discussed that this is sub-optimal since
                  very few users actually work straight out of trunk.
                  Sorry JimK, you will ned to use "/trunk" to find it
                  into the future.  When we finalize the 2.6 docs, we
                  will mark that as the "current" branch in the doc
                  build scripts and point "/" to that.
>>>This change has not effected the organization in SVN
                  so Eli, myself, and others should be able to continue
                  as normal.
>>>There are also two super-nerd changes we should
                  consider:
>>>1) Support IPv6.  This is a tenant of JimK's religion.
                   While I'm not observant of his church, I think it
                  certainly would like to see us execute on this
                  particular project.
>>>2) SSL?  A freebie signed certificate is available but
                  I'm really not sure it's necessary as we do not
                  collect, require, nor disseminate PII.
>>>_______________________________________________
>>>Geomoose-users mailing list
>>>Geomoose-users at lists.osgeo.org
>>>http://lists.osgeo.org/mailman/listinfo/geomoose-users
Geomoose-users mailing list Geomoose-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111129/6e63f025/attachment-0001.html
More information about the Geomoose-users mailing list
