[Geomoose-users] GeoMoose API: GeoMOOSE.turnLayerOn problem with
multi map-source layers
Dan Little
danlittle at yahoo.com
Mon Apr 16 20:53:32 EDT 2012
Jim's right, we should be able to integrate this patch.
>________________________________
> From: Jim Klassen <klassen.js at gmail.com>
>To: Brent Fraser <bfraser at geoanalytic.com>
>Cc: Dan Little <dan.little at excensus.com>; GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
>Sent: Monday, April 16, 2012 2:46 PM
>Subject: Re: [Geomoose-users] GeoMoose API: GeoMOOSE.turnLayerOn problem with multi map-source layers
>I don't think we've made the 2.4.1 release yet either. I have already applied some fixes in branches/geomoose-2.4 in anticipation for the 2.4.1 release (update for Mapserver 6.x and the famous extra comma). I think it is all sitting pending testing. My main confusion is that the 2.4.0 tarball and the 2.4.0 tag and branch in SVN somehow ended up at slightly different versions and I'm not sure which is most correct.
>On Apr 16, 2012, at 2:08 PM, Brent Fraser wrote:
>Dan,
>> I'm using the GeoMoose API (v2.4 I think) in a JavaScript user
extension to turn on a multi-mapsource Layer:
>> GeoMOOSE.turnLayerOn("Image/image:Filler/all");
>>In geomoose.js, turnLayerOn calls changeLayerVisibility, where the
layerpath is split and the DOM is queried for each portion. But
those portions are Map-Sources, not Layers, and therefor are not
found.
>>So I changed the code to simply query on the original path (not the
portions), and it seems to work:
>> changeLayerVisibility : function(layerPath, visibility) {
>> var paths = this.splitPaths(layerPath);
>> for(var p = 0; p < paths.length; p++) {
>> var e =
document.getElementById('catalog-'+paths[p]);
>> if(!e &&
!Catalog.setLayerVisibility(paths[p], visibility)) {
>> OpenLayers.Console.log('Layer '+paths[p]+' does
not exist');
>> } else if(e && e.checked != visibility) {
>> e.checked = visibility;
>> e.onclick();
>> var e = document.getElementById('catalog-'+layerPath);
>> if(!e && !Catalog.setLayerVisibility(layerPath,
visibility)) {
>> OpenLayers.Console.log('Layer '+layerPath+' does not
exist');
>> e.onclick();
>>If you think the above fix is valid, I'll file an Issue in Trac (I
guess we're still filing issues on v2.4), and put the fix in SVN.
>>Thanks!
Best Regards,
Brent Fraser
>>Geomoose-users mailing list
>>Geomoose-users at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/geomoose-users
>_______________________________________________
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120416/4b532cfb/attachment-0001.html
More information about the Geomoose-users
