[Geomoose-users] Catalog->group - can't get GM to start with group folder closed
Jim Klassen
klassen.js at gmail.com
Mon Aug 13 12:11:18 PDT 2012
What else did you do besides copying the directory (\ms4w\apps\geomoose2) under a new name (\ms44\apps\geomoose3)? I just tried copying the directory and it is not enough for MS4W to pickup the new name — it doesn't find it at all.
If I also copy and modify \ms4w\httpd.d\httpd_geomoose2_ms4w.conf to \ms4w\httpd.d\httpd_geomoose3_ms4w.conf and replace all occurrences within of geomoose2 with geomoose3, the demo works as expected.
Presumably, \ms4w\apps\geomoose3\local_settings.ini should also be modified as well to use the copied version of the mapfiles, etc.
On Aug 13, 2012, at 1:24 PM, Bistrais, Bob wrote:
> Just to be sure, I’ve just downloaded the latest GM 2.6 download. I unzipped the demo app and it works normally. Then I made a copy of it under a new name. When I open this application, all folders are expanded. They are both residing in the same ms4w/apps directory, the only difference is the application folder name. Any ideas?
> From: Jim Klassen [mailto:klassen.js at gmail.com]
> Sent: Monday, August 13, 2012 1:16 PM
> To: Bistrais, Bob
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Catalog->group - can't get GM to start with group folder closed
> Resend: Message got too big for the list.
> There is something wrong with your GeoMoose install (as opposed to your mapbook). I also checked and your getmapbook.php is returning the mapbook you sent in the email. Are you sure you are using the released and/or latest version?
> I put your catalog into my app and it shows up like this to start.
> <image001.png>
> And the "nested" same groups show up when you click on them...
> <image002.png>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120813/d1de0b4b/attachment.html>
More information about the Geomoose-users
