[Geomoose-users] Problem with footer in select.php
Anderson, Dean anderson.dean at co.polk.or.us
Thu Aug 30 11:55:04 PDT 2012
Brent
Adding <!-- MapServer Template --> to my HTML fixed it!
I am aware of the stuff in the settings.ini file and had that covered. I am
testing the customization part for the select tool and wanted to test
having a layer specific footer.
THANKS!
Dean
On Thu, Aug 30, 2012 at 11:45 AM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Dean,
>   Don't forget there's an [Identify] section in the settings.in for
> global header and footer.
> And your footer.html may need Mapserver's magic string at the top:
> Best Regards,
> Brent Fraser
>  On 8/30/2012 11:29 AM, Anderson, Dean wrote:
>  I am not sure if this is a bug and I need to verify before submitting
> ticket.  I am not able to display a footer using the select service
> (select.php).  This is what I did..
> 1. Created a "select_footer.html" file in the maps\demo\parcels\templates
> directory.
> 2. Added the reference to the Metadata section in parcel.map
> 'select_footer' 'templates/select_footer.html'
> 3. Cleared cache and ran demo - not display of footer stuff.
> 4. Checked the select.php to see if I had my reference for the footer is
> correct.  Found the line:
> if($layer->getMetadata('select_footer')) {
>   $layer->set('footer', $layer->getMetadata('select_footer'));
> Based on some simple tests it appears my file is being loaded in
> select.php, so I think it is being referenced correctly but does not
> display.  Any ideas on how to make this work would be much appreciated.  It
> is the last test I need to do in customizing the app for select.
> Dean R Anderson
> IT Director
> Polk County
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
Dean R Anderson
IT Director
Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120830/b1b03fe0/attachment.html>
More information about the Geomoose-users mailing list
