[Geomoose-users] Problem with footer in select.php
Anderson, Dean
anderson.dean at co.polk.or.us
Thu Aug 30 13:56:56 PDT 2012
So...
Now I am testing the itemquery stuff for query.php. I made the header and
footer work fine using the settings.ini file (thanks for that suggestion
and am testing it pretty well). However, I think I should also be able to
make this work using the reference in the parcels.map file with something
like...
'itemquery_header' 'templates/header.html'
'itemquery_footer' 'templates/footer.html'
Unfortunately this does not seem to work. Am I messing up? When I have
the files in the itemquery directory (as referenced in the settings.ini)
file they work fine. However, when I have them in templates directory for
parcels they do not work at all. I am not sure what is up.
I am trying to finish this up to complete my query customization test and
documentation.
Any ideas??
Dean
On Thu, Aug 30, 2012 at 11:55 AM, Anderson, Dean <
anderson.dean at co.polk.or.us> wrote:
> Brent
> Adding <!-- MapServer Template --> to my HTML fixed it!
> I am aware of the stuff in the settings.ini file and had that covered. I
> am testing the customization part for the select tool and wanted to test
> having a layer specific footer.
> THANKS!
> Dean
> On Thu, Aug 30, 2012 at 11:45 AM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>> Dean,
>> Don't forget there's an [Identify] section in the settings.in for
>> global header and footer.
>> And your footer.html may need Mapserver's magic string at the top:
>> Best Regards,
>> Brent Fraser
>> On 8/30/2012 11:29 AM, Anderson, Dean wrote:
>> I am not sure if this is a bug and I need to verify before submitting
>> ticket. I am not able to display a footer using the select service
>> (select.php). This is what I did..
>> 1. Created a "select_footer.html" file in the maps\demo\parcels\templates
>> directory.
>> 2. Added the reference to the Metadata section in parcel.map
>> 'select_footer' 'templates/select_footer.html'
>> 3. Cleared cache and ran demo - not display of footer stuff.
>> 4. Checked the select.php to see if I had my reference for the footer is
>> correct. Found the line:
>> if($layer->getMetadata('select_footer')) {
>> $layer->set('footer', $layer->getMetadata('select_footer'));
>> Based on some simple tests it appears my file is being loaded in
>> select.php, so I think it is being referenced correctly but does not
>> display. Any ideas on how to make this work would be much appreciated. It
>> is the last test I need to do in customizing the app for select.
>> Dean R Anderson
>> IT Director
>> Polk County
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
> Dean R Anderson
> IT Director
> Polk County
Dean R Anderson
IT Director
Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120830/eb6c4cf9/attachment.html>
More information about the Geomoose-users
